M
Myles
Hello everybody,
First of all I would like to thank everybody who helped me with the 'milky rad question', problem is solved.
It seems my truck is having problems getting into second, but only when the tranny is cold. There is no slipping and the fluid level is fine, but not as red as I would like to see. I can manually put it into second with ease, and again manually put it into D or OD then the tranny will work fine for the rest of the drive. But after work, the same problem happens and the only way to get rid of it is to drive for about 20km manually switch the gears first,second and then into drive or OD then it works fine for the rest of the drive.
Any suggestions?
Lifes to short not to drive the beaten path
1994 XLT 4.0 Loaded
and loving it
[This message has been edited by Myles (edited 06-08-1999).]
Any suggestions?
1994 XLT 4.0 Loaded
and loving it
