SwampFox89
- March 12, 2006
- Marion, NC
- '99 Explorer
So I've searched the threads on here for days and decided to break down and start a new one to answer my problems.
First I will list my symptoms with my '99 Ex Sport, OHV. ~150k miles
1. Terrible mileage, about 13 mpg
2. Starting takes a hair longer after she sits for a couple days than when I drive every day.
3. Idling is rough when in gear at a stop sign or red light but not in park.
4. When I touch the pedal to go from said stop, she gets sluggish, then picks up.
5. CEL comes on for the occasional misfire, and frequent lean mix codes on both banks.
6. Going up hills, pressing down on the gas as much as I used to, it feels like she changes gears, the RPMs go to about 2200, like she used to, then drop to about 1250. Once it gets to about 1250, I lose about 60% of my hp and can't go more than about 45mph, until I floor it, and the gears change again. When it's down at that 1250, it also rumbles, like the engine is bucking and I can feel it straight through my steering wheel, into my shoulder.
7. In general, I've lost about 15% of my normal power.
8. Fuel needle seems to have a huge margin in a short period of time. Like when I'm facing downhill, the needle will drop, and when accelerating uphill, it goes up. The lowest to the highest can be about a quarter tank difference.
9. Replaced some injector o-rings that were getting bad.
Now let me throw in any relatively recent repairs I've done myself, regardless of relation to the problems.
1. Cleaned MAF sensor
2. Replaced TPS (I broke it once, derp)
3. Replaced the gaskets between the intake plenum and fuel rail and the gasket below the fuel rail. When I checked for vacuum leaks, this was the only place I found a leak, so I fixed it, correctly, torque to spec and everything.
4. Cleaned throttle body
5. Replaced IAC valve
6. Replaced fuel and air filters
7. Replaced PCV valve
8. Ran seafoam through the air intake (correctly through the vacuum line)
9. Ran 2 bottles of injector cleaner and seafoam through the gas tank (not at the same time of course)
So I'm thinking my next step is to take it to a trusty guy at a local family shop and him test vacuum pressure everywhere and if that doesn't work out, then I'm thinkin something with the fuel tank, the pump going bad, the pressure damper being clogged or something. I also haven't ruled out a bad DPFE sensor (even though I haven't had any codes for it) or the EGR valve, which should also throw a code...
Any help would be greatly appreciated, as I have a new job, with a long drive and money's tight right now.
Thanks fellow explorers...
