I have a '93 Explorer and the cruise control worked off and on intermittently and finally quite working. I went through a bunch of threads on this site and I think I narrowed it down to a bad cruise amplifier or a bad servo. I checked the fuses, the horn works, vacuum lines seem properly connected and good, and the vacuum dump valve is properly adjusted.
How can I narrow it down between the cruise amplifier and the servo--are there any tests I can run or anything to look for to tell if one or the other is good or bad? Thanks!
