Redlos
- August 1, 2002
- Gonzales, LA
- '96 XLT
My '96 Explorer XLT auto-lock/keyless remote mysteriously stopped working!
I've already read MANY threads on this problem...so here's where I am:
I know the factory code and it won't work
I've tried:
1. Turn the ignition key to ON.
2. Press the power door unlock control three times.
3. Turn the ignition key from ON to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition key back to ON. The doors will lock and unlock.
6. Press the power door unlock switch. The horn will chirp once upon successful toggling of the Autolock feature.
7. Turn ignition to OFF. The horn will chirp to confirm procedure is complete.
The horn chirped but the locks DIDN'T cycle.
I've tried:entering the permanent code (w/in 5 seconds, depress and release 3/4 while holding 7/8 key....NADA
I'm completely stumped...is there a fuse I don't know about? None are listed in the owners manual/Chilton's/fuse panels for keyless entry or auto-lock!
Is my module broken?? I've already unplugged/replugged the wiring harnesses/cables!
ANY suggestions would be greatly appreciated!!
I've tried:
