mykal
- May 27, 2005
- Carmichaels, PA
- '95 Limited
Troubleshooting Sunroof, Map Lights, A/C, CEL, Wipers
Tonight I bought a '94 Limited. I tried to read around but couldnt find anything.
Sunroof
I found a set of wires, red/red(black) that were clipped near the bottom of the front door. I traced them back to the sunroof switch. I sent power to them and used a meter to test the current. I had power to the switch and the switch works. Yet, when I press it, absolutely nothing happens. No sound, no movement, nothing. What should I check next?
Map Lights
Bulbs are good, fuses are good. What should I check?
A/C
Turn it on, blows hot air. What can I do to fix this? I fear messing with A/Cs as I always hear its soo expensive, is this true?
CEL
After driving for about 20 mins my check engine light comes on. Is there a way to pull the codes without a scanner?
Windshield Wipers
When I turn them on they dont turn on unless it is on the fast setting. Intermittent and slow produce no noise or anything. Where should I start troubleshooting?
Thank You!
Sunroof
Map Lights
A/C
CEL
Windshield Wipers
Thank You!
