Afboy143
- September 23, 2003
- Tampa,FL
- 1999 Ford Explorer Sport
Hey guys,
I haven't posted here in years. A few years back I gave my explorer to my sister and bought a Mustang and started to really be on those forums.
My sister brought my old 1999 Ford Explorer Sport 4.0L SOHC to me saying it's giving her really bad gas mileage. The truck has 170K miles on it.
It had codes so I pulled them, P0171 and P0174. While poking around the engine I found the PCV valve was out of the tube it sits in. I also found the T connector that connects the PCV valve to the hoses going into the upper intake was cracked. I replaced the PCV valve and used a generic T connection utilizing a universal T connector and fuel line. I put a clamp around the hose for the PCV valve so it doesn't come back out.
I cleaned the MAF as it was really dirty.
I also replaced the thermostat in the housing as it was leaking so I figured if I'm replacing the gasket, why not the thermostat as well.
Fuel filter was replaced with a Drive Works generic filter from Advance Auto.
Upon removing the throttle body to clean it, I found wet liquid behind it and the build up of carbon was unreal. I thought this might be to the PCV valve falling out of the tube and not doing it's job for God knows how long.
My question is after doing all the above, the truck smokes pretty bad at idle (which it didn't do before). It's a white smoke. Also, you can smell a strong smell of burnt carbon upon heavy acceleration. Is this because the PCV valve is actually doing it's job and there is so much crud in there?
The truck also starts up rough and idles rough for a minute after sitting for hours, but if you drive it and let it sit for minutes, it starts right up without hassle.
I have no idea what to do, and the codes mentioned above are still present. Any ideas?
