Truck will not start IMPORTANT | Ford Explorer - Ford Ranger Forums - Serious Explorations
Stinger357
Plano, Texas
1997 Ford Explorer Eddie
I have an interview in 1 hour I need to be at and my 97 4.0 SOHC v6 will not start. It seems to be turning over ok but just not either getting fuel or a spark. I tried for 20 min. Any idea on how to get it started I need it bad. Computer says I have 2 gallons in the tank and I am also on an incline.
Turdle
The Lowrider is a little higher
Staff member
Moderator
Humboldt, KS
2000 Mounty
If you are facing downhill, this may be a problem. Try some more fuel in the tank, or, last resort floor the gas pedal while cranking engine.
OneLever
97 Mt. 5.0L AWD
Have you had any previous problems? Is the CEL on?
If not probably just the fuel pump pickup can't get any of the gas. Put it in neutral and coast to a flat area and try again. Or if flat areas are too far away put it in neutral and turn sideways on the incline so the truck is level from front to back. It will obviously not be level from side to side.
Stinger357
Plano, Texas
I used your advise and floored the pedal while trying to start it and it worked!!! So I reved it up and warmed it up and drove it to the nearest gas station and filled it up! I should have never let it get that low with an important interview coming up! Thanks for all your help!
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
These things always happen when you have an interview - I once locked the keys inside my car 20 minutes before an interview.
