Truck wont allow me to shift to reverse or park
jredd823
salisbury, md
my gf has a 1998 ford explorer with around 180,000 miles on it. the tranmission has always shifted roughly, but recently i have lost the ability to shift the car into park when i get home. I was able to go to reverse until today. I have to start the truck in neutral and push it backwards to get out of a parking spot. I am sure that someone here has dealt with this before, but i must be using the wrong search parameters because i havent seen a "fix" for it. I recently bought a haynes manual to try to fix any problems i come across... Thank for your help.
one more thing... is there any way to get my shifter to stop feeling so loose when i am selecting which gear to use.
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
jredd823
salisbury, md
thanks a lot. i really appreciate it.
R 1996 truck wont start Stock 1995 - 2001 Explorers 0
R 1996 truck wont start Stock 1995 - 2001 Explorers 1
R Truck wont start Stock 1995 - 2001 Explorers 19
P truck wont heat up! Stock 1995 - 2001 Explorers 3
F truck wont stay in park Stock 1995 - 2001 Explorers 6
K Why wont my truck start after its been running a while? Stock 1995 - 2001 Explorers 24
T Truck wont start but will turnover Stock 1995 - 2001 Explorers 13
M Truck wont start Stock 1995 - 2001 Explorers 9
L My truck wont start....help Stock 1995 - 2001 Explorers 3
C Help pls!!!! Truck wont start Stock 1995 - 2001 Explorers 3
S abs light andand truck wont start Stock 1995 - 2001 Explorers 3
I Live data video of my truck Stock 1995 - 2001 Explorers 20
C Replace engine or replace truck? SOLVED Stock 1995 - 2001 Explorers 26
Z I think my truck is stuck in 4wd Stock 1995 - 2001 Explorers 12
C Replaced ignition but truck won't start. Stock 1995 - 2001 Explorers 17
S Stuck in 4 wheel low and truck thinks its in 2 wheel drive Stock 1995 - 2001 Explorers 9
W Truck won't start Stock 1995 - 2001 Explorers 5
9 Electrical help -- dead truck. Problem w/ fuse box Stock 1995 - 2001 Explorers 3
H Old truck high RPM Stock 1995 - 2001 Explorers 1
K Issue with keeping truck running 97 explorer Stock 1995 - 2001 Explorers 0
I 2002 ford truck question,can anyone help Stock 1995 - 2001 Explorers 1
M Extend seatbelt outside of truck? Stock 1995 - 2001 Explorers 0
P Two more questions.. (Truck refused to start and some more about Head/tail-lights) Stock 1995 - 2001 Explorers 7
E Looking to buy 1997 Explorer V8 AWD w/ 100k - having 20 year old truck jitters Stock 1995 - 2001 Explorers 13
R Bad idle after truck is warmed up Stock 1995 - 2001 Explorers 3
T Help.....truck just died on the way to work. Stock 1995 - 2001 Explorers 21
J 2wd mud truck Stock 1995 - 2001 Explorers 7
D Bought a Parts Truck Stock 1995 - 2001 Explorers 7
toypaseo KYB was the original sourced shock when the truck left the factory? Stock 1995 - 2001 Explorers 6
B HELP A.S.A.P, filler tube Fueltank leaking. Smell gas arround my truck. Stock 1995 - 2001 Explorers 5
G Replace Seal Behind Shift Motor on Truck? Stock 1995 - 2001 Explorers 0
S Truck won't start. Need some help. Stock 1995 - 2001 Explorers 8
9 HELP! truck wouldnt start this morning. ECT sensor? Stock 1995 - 2001 Explorers 3
M How much can my truck pull? Stock 1995 - 2001 Explorers 12
B Here's how the truck sits now Stock 1995 - 2001 Explorers 6
B Tried Everything I could think of. Truck won't start!!! Stock 1995 - 2001 Explorers 8
M Truck won't start Stock 1995 - 2001 Explorers 2
K Truck totally dead? Stock 1995 - 2001 Explorers 7
D fix my truck Stock 1995 - 2001 Explorers 1
B Quick Help: Bad clutch = truck won't fire up!? Stock 1995 - 2001 Explorers 6
P Can i use diesel truck oil ? Stock 1995 - 2001 Explorers 9
R How do I tell if my truck has PATS? Stock 1995 - 2001 Explorers 4
U *Help* Truck didn't start, day later it did. Stock 1995 - 2001 Explorers 10
D Help with pricing my truck for potential sale? Stock 1995 - 2001 Explorers 6
B Burnt oil/rubber smell coming from under truck and cat smoking Stock 1995 - 2001 Explorers 4
9 I swear, it just followed me home last night (new truck) Stock 1995 - 2001 Explorers 31
M What's my truck worth? Stock 1995 - 2001 Explorers 6
C Truck hasn't run in years, no oil pressure Stock 1995 - 2001 Explorers 10
B Truck over heating Stock 1995 - 2001 Explorers 7
S Brake fluid leak inside truck? Stock 1995 - 2001 Explorers 2
Similar threads
