TS & Flasher Work but no Chimes | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership!
    If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
L_turn9
Location
Chester, Va
Chester
2006 Explorer 4.0 V6 4WD
Hello - As I said,on my 2006 Explorer XLT 4WD, the Electric gimos work, but the chimes are silent; ie, the T/S works - but there is no clicking, the Hazards work - but no flashing. the Seat Belt Warning in the Display works when a belt is not clicked - but no Warning Chimes - same for other warnings. Could this be the flasher or something else? Not sure what other warnings I could check.
I've never had a problem like this before....
Thanks -
L_turn9
Location
Chester, Va
Chester
Thanks -
I proofed this 4 times and still posted an error! I wrote: " the Hazards work - but no flashing" when i intended. " the Hazards work - but no Clicking". Sorry
J_C
Florence, KY
1998 XLT 4WD 4.0L SOHC
I don't know about the warning chimes but the hazard and turn signals do seem like your flasher relay failed.
Bazz270
Haifa,Israel
Ford Explorer 2007 XLT
No flasher relay at gen4.
Chime speaker is a build-in instrument cluster feature.take the IC apart and you will see his printed motherboard with the speaker soldered inside for inspection.
L_turn9
Location
Chester, Va
Chester
Thanks for the suggestion! That's what I thought too, but having all the sounds go bad at one time seems odd, of course odd things happen! ;-)
J_C
Florence, KY
If there's no mechanical relay (probably transistorized now?) maybe check the owner's manual to see if there is a way those are disabled, maybe somehow that happened?
Seems easier than tearing the instrument cluster out, and measuring for a low AC voltage to the speaker (probably a piezo driver?) when it should be making sound. Those don't usually blow out unless something upstream of it is faulty too, or maybe a bad solder joint, don't know.
