tt lift after problem | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
moose1
coupville, wa
99 xlt
Ok so i did the tt lift maxed out the bolt but it seems there is a wierd noise, like a kreeking noise everytime i start to a ccelorate from a stop, what could this be, anyone heard of this before.
Holiday Special! Join the Elite Explorers $20 for 2 years! Gets rid of the ads!
explorermatt001
Mission Viejo, CA
97 XLT 4x4
are u 4wd, if so the front driveshaft could be loose since u completely cranked the t bars
moose1
coupville, wa
99 xlt
how do i check this?
explorermatt001
Mission Viejo, CA
97 XLT 4x4
look for a short driveshaft that runs from the transmission to an axle that runs from each wheel to the center of the front suspension. in the middle there shuold be an axle where the shaft connects, see if it is loose or if there is a lot of play in it
moose1
coupville, wa
99 xlt
It seems to be coming from the back thow, as i just noticed, could it be my shocks if i still have factory ones or could it be my leafs and the shackels, but i will go check the shaft right now.
moose1
coupville, wa
99 xlt
well i just layed under the truck, and get this the leaf spring on the passenger side isnt sitting flush to the axle theres like a 1' gap, wtf, i've been driving like this. I had a shop take the blocks out of the back and it looks like they didnt tighten down the u bolts. But either way the shocks are making that stupid kreeking noise, is this normal if there worn or is it because of the lift. I used shackels for the back there not making any noise thow.
dreamr
Lynnwood WA
99 XL / 4x4 / 4.0 ohv
If the shocks are old they may just need replaed. You have to figure that they are now operating in a static range that they have never before operated in.
As to length. I still run the stock length shocks and have had no problems. They do stop the front about an inch before the CV shaft binds, but to me that is a good thing. On the rear they allow for plenty of articulation.
The shackles will get squeeky as hell once they wear in and get a bit dusty. I try to keep them lubed in the winter to keep it quiet, but come summer I travel hundreds of miles of dirt roads so just ignore it. They are loud though! Ask Albino he has got to listen to me squeek up many a trail.
