RustySJohnson
- July 11, 2011
- Indianapolis, Indiana
- '94 Limited
I'm prematurely posting a build thread as I believe I have a cure for the TTB steering woes, maybe not the cure, but a cure, and I'm not using a Superrunner kit, or a complex swingset. Parts are on order, and a majority have just arrived. I'll either be hailed as a hero genius or lauded as one of the pariah's on the http://128.83.80.193/scarysteering/index.html site. I'm going out on a limb here, bare with me.
I've been reasearching a solution for a while, hand drawn a few sketches, stared at the front end for hours, and have found many respectable setups only to find myself to not be satisfied with the cost of a custom fabrication shop, unhappy with shopping cart type bolt on options, or accepting handling compromises.
I'm in this pickle because I installed the Skyjacker 8" TTB bracket lift with 1.25 front coil spacers and the FA600 drop pitman arm. The steering geometry is gone. Here's a link: 8" Skyjacker Lift for '92 Ranger on a '92 Ex???
BOM
Off-Road Fabrication Parts - RuffStuff Specialties
Qty (3) P/N: 7818TA, 7/8" Hex Head TRE Tube Adapter (18TPI) RH 1" Tube ID $12.00 36.00
Qty (1) P/N: 7818TA, 7/8" Hex Head TRE Tube Adapter (18TPI) LH 1" Tube ID $12.00 12.00
Qty (3) P/N: 7818JAM, 7/8" TRE Jam Nut (18TPI) RH $4.80 $14.40
Qty (1) P/N: 7818JAM, 7/8" TRE Jam Nut (18TPI) LH $4.80 $4.80
Shipping $6.20
Subtotal1: $73.40
Delivery: Shipped same day, arrived in two. California to Indiana
Comments: Provided excellent customer service via phone. Added to my order after I realized my counting error and provided measurements upon request.
YOUR OFF-ROAD PARTS SOURCE! | POLY PERFORMANCE
Qty (1) P/N: PPM-3620-07-18-10 Synergy Suspension Double Adjuster Tube Adapter, ID Tube Size: 1" ID Tube (7/8"-18 LH)
$45.00
Shipping: $12.08
Subtotal2: $57.08
Delivery: 14 days.
Comments: Excellent Technical assistance, provided part dimensions upon request. Item overpriced. Shipping inflated.
RideTech.com - Performance Suspension Specialist
Qty (2) P/N: 90000188, Large Rod End Bracket for 3" Wide Rod End $15.00 $30
Qty (2) P/N: 90000195, Weld-On Sleeve 2-7/16" width - 3" w/bushing $6.75 $13.50
Tax: $3.04
Shipping: $14.59
Subtotal3: $61.13
Delivery: 9 days. Southern Indiana to central.
Comments: I had to pay state sales tax, not their fault, just makes me want to order out of state. Sleeves didn't include bushings, I misunderstood the description, my fault mostly. Couldn't order the bushing online, I had to call to get the P/N and then place the order separately via phone. Provided part dimensions upon request. Great online C/S chat tool. Long delivery lead time.
Warner Steel Sales
DOM tubing 1 1/2" od x .250 wall - 1.0" ID $10.00 p/ft X 6ft = $60.00
Qty (1) 30.5" - Drivers side tie rod
Qty (1) 22.5" - Passenger side tie rod
Qty (1) 15.5" - Drag Link $
Qty (1) 8" X 18" X 3/4" flat steel plate $17.50 p/ft X2 = $35.00
Shipping: No charge, local pickup
Tax: $6.65
Subtotal4: $101.65
Comments. I only needed 18" 3/4 steel plate, but they charged me for the full 2' (they rounded up). Next time, I'll ask for an 18" and 6" so I get my money's worth. I'm always needing extra steel. They cut to length, no wait. Friendly staff. They close at 5pm, SHARP. It took me two trips. I arrived at 5:07 the first time, because I got lost and was driving my steeringly-challenged X-plorer, not their fault.
http://www.summitracing.com/parts/ENS-9-9489R/
Qty (1), 1.5 OD Polyurethane bushing, Set of two, $16.95
Shipping: $4.95
Tax: None
Subtotal5: $21.90
Delivery: 2 Days
Comments: Shipped same day.
Duralast Center Link ES2913R - Read Reviews on Duralast #ES2913R
Qty (3) P/N ES437L, 7/8" (18TPI) 9/16" stud tie rod LH, $16.99 $50.97
Qty (2) ES2913R, 7/8" (18TPI) 9/16" stud tie rod RH, $16.99 $33.98
Tax: $5.95
Shipping: None, Local Pickup
Comments: Ask for 1975 Ford E150.
Subtotal5: $90.90
Odds and ends:
1 Each White primer and Red enamel = $14.00
Qty (2) 16mm x110mm bolts, nuts and washers $25.00
Grease Zerks $5.00
Motion Industries – Industrial Supplies, Bearings & Equipment
Item Number02143966
DescriptionID - 3/4" OD - 1-1/2" W - 1", Sealed On Both Sides, Caged Roller Bearing
MFG. Part NumberMR 16 SS/MI 12
Manufacturer MCGILL BEARING COMPANY
Available InventoryAvailable
Qty (4) - Price $39.87 $180.00
Farmed out labor:
Finish Welding, pipe bending, inner tie rod plate drilling and machined tapers $150.00
Grand Total: $780.06
Install Time 8 hours
In an effort to reduce posting clutter, I'll be editing this post on this thread often with pictures, details, information, links, and spelling/grammar corrections. I estimate 3 weeks till I'm finished with the build.
As soon as I can provide additional details, pictures, etc.. I'll be starting an additional alignment thread (post link here). I have access to a state of the art Italian alignment rack made by Ravaglioli. I have gained valuable experience with aligning the TTB myself, and have exceptional success just by eye and feel on the first gen Explorer. I'd like to share that knowledge with the DIY'rs and Wheeler's alike.
TBC.... Rusty
BOM
Shipping $6.20
Subtotal1: $73.40
$45.00
Shipping: $12.08
Subtotal2: $57.08
Delivery: 14 days.
Tax: $3.04
Shipping: $14.59
Subtotal3: $61.13
Warner Steel Sales
Tax: $6.65
Subtotal4: $101.65
Shipping: $4.95
Tax: None
Subtotal5: $21.90
Delivery: 2 Days
Tax: $5.95
Subtotal5: $90.90
Odds and ends:
Grease Zerks $5.00
Item Number02143966
Farmed out labor:
TBC.... Rusty
