Turbo Lag | Ford Explorer - Ford Ranger Forums - Serious Explorations
Turbo Lag
whimsey
sparta, nj
2017 XLT
My wife has a 2017 2.3 EB Explorer. It accelerates fine EXCEPT if you floor it either from a dead stop or even while rolling. Flooring it is not done often however It's done this lag from new. There seems to be a hesitation, it doesn't stall but doesn't accelerate until a few seconds later, then it's fine. "Normal" everyday acceleration is great. It has a twin scroll single turbo which is suppose to ramp up quickly. Anybody else experience this "lag" with their Ecoboost engines when they floor it? It may be the nature of the "beast" but I'd be interested in other peoples experiences with their Ecoboost's and flooring it.
Whimsey
Join the Elite Explorers $20 each year.
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
WILMAC
2020 Ford Explorer ST
I believe drive by wire is the problem with a slow throttle response. My 17 platty has the same problem. My 12 MKt did not. I understand peddle commander will fix the problem.
RhinoQuartz
17 Explorer Base
Whimsey
Have you tried it in Sport mode 'S'?
I've found that throttle response is faster than in Drive 'D'.
613GT500
Ontario, Canada
2016 XC90 T8 R-Design
Autotragic...
whimsey
sparta, nj
2017 XLT
No, I've not tried "pedal to the medal" in Sport but will do first chance I get, thanks. I do usually use sport mode in "local" back road driving the rare time my wife let's me drive it ;).
Whimsey
whimsey
sparta, nj
2017 XLT
Thanks, what is "peddle commander" and how does it work?
Whimsey
613GT500
Ontario, Canada
What does "Autotragic" mean?
Whimsey
Sorry, it's a term (at least my group of friends up here)we use when comparing an automatic transmission vehicle to a manual transmission vehicle...as in the latter being a tragic in terms of overall driving experience and response.
jhu8
Maryland
2022 Ford Explorer ST
I have experienced this in my 2.3L as well. I haven't tested it lately but from what I remember, it really is only if you the pedal down all the way.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Whimsey
Lots of info on the Internet.
https://www.pedalcommander.com/?v=3e8d115eb4b3
Pedal Commander is a throttle response controller that removes response delays on your electronic accelerator pedal. Effectively, it allows your engine to respond faster so your car can accelerate faster!
RhinoQuartz
17 Explorer Base
As I understand it, it's possible for the same effect to be achieved by using zip ties to take the slack out of one's throttle cable. Which is literally 1000x cheaper.
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
There is no throttle cable.
PlatinumOwner
Orange County, CA
2016 Explorer Platinum
whimsey
sparta, nj
2017 XLT
Yep, the same thing only if I you go full throttle, otherwise it's fine. That rarely happens but sometimes you need full throttle unfortunately.
Whimsey
Barry Trobaugh
Memphis Tennessee
2018 Platinum
Someone with some expertise or technical knowledge needs to chime in.
If selecting Sport Mode (S) changes the throttle actuation, that would be a winner.
Any other suggestions?
Explorer75
2013 Ford Explorer XLT
Whimsey
What gas are you using? If it´s 87 octane regular I´d suggest at least 91, better if 93 premium. I know what the manual says, you can use 87 bla bla bla. The best performance comes with 93 octane. With regular the PCM retards timing, lowers boost. It´s a whole different map to protect the engine, performance is going to suffer.
Give it a try, it only costs a few more bucks.
RhinoQuartz
17 Explorer Base
You'll need a few tanks of 93 to see a difference.
And it really isn't worth it, unless under severe driving conditions, such as very hot weather or towing.
