Explorer Forum Covers the Explorer ST, Explorer Sport, Explorer Sport Trac, Lincoln Aviator,
Mercury Mountaineer, Mazda Navajo, Ford Ranger, Mazda Pickups, and the Ford Aerostar
Register Today It's free!
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an alternative browser.
Turbo on 2000 Limited 5.0
- Thread starter Dono
- Start date
Add an avatar, upload photo attachments, and more!.
- April 3, 2008
- Gloucester City, NJ
- 98 2Dr,2,000 & 04 4dr xlt
Even without paint it is an awesome looking set up. Glad the new turbo set up is building boost sooner like you wanted.
I guess if that port is missing you have no working boost gauge either?
Will be waiting to hear how it does when it is all ready to go hard on it.
- January 22, 2007
- selkirk, manitoba
- 98 supercharged 347 sport
that looks snazzy. not looking forward to seeing it on a regular basis if you know what i mean.....
- February 18, 2009
- Winnipeg, Manitoba
- 04 Mustang GT
Quick update. No boost control. The waste gate can't vent enough exhaust gasses. lol
The 38mm wastegate that I currently have is too small. I was going to use an adapter, but Bill at Bullseye power emailed me back and said that an adapter won't work as the exhaust flow won't be there. This means another trip to my good friends at the exhaust shop.
Rather than continually cutting the exhaust off after the muffler, I'm going to have them install a v-band this time, lol. The v band will probably mean I will never have to pull the exhaust off again (Or at least I hope so).
Having a resource like bullseyepower has been priceless for me. Rightsizing components is so important. Knowing what I know now, I just don't know how guys can just slap anything together and make big reliable power.
My truck is officially leak free. First time in probably close to 2 years. I just replaced my transfer case output seal, and that could very well be the end of the all dripping for the moment. I'm pretty happy about that.
- January 22, 2007
- selkirk, manitoba
You had to say it, didn't you....that could very well be the end of the all dripping for the moment.
- February 18, 2009
- 04 Mustang GT
I am still knocking the intercooler pump control thing around in my head.
I was thinking pulse width modulation using the tps sensor. Problem with this is at low pulses, the coolant probably isn't moving enough.
I'm thinking this product:
http://www.autospeed.com/cms/article.html?&title=Incredibly-cheap-voltage-switch&A=113008
With this, I could separate the tps from this unit with a diode, and still use the pot to adjust on voltage so the inter-cooler come on full at part(say 1/4) throttle. with this setup, I could use a switch in the cabin (Wired in-between the diode and voltage switch) to key the inter-cooler pump to have it on all the time if I wanted without affecting the tps voltage.
This would accomplish my requirement of the inter-cooler pump not drawing current in stop and go traffic but yet run when the rpm's are a bit higher and the alternator can supply enough current under all conditions.
The adjustable pot on the voltage switch makes me think this is the correct way to go.
- January 22, 2007
- selkirk, manitoba
i was thinking about this a few days ago. could you not have it triggered to your meth controller?
- February 18, 2009
- 04 Mustang GT
The intercooler pump needs to run much more than the w/m pump. It's the idling with air/e fan/air cond/headlights that becomes an issue. if I can have the pump turn on, and stay on, at anything over a quarter throttle id be good. I doubt it would bother to turn on under normal driving, but would turn on before hitting boost.... its the continuous run for a minute or two after hitting boost I haven't figured out yet.
- February 18, 2009
- 04 Mustang GT
I completed another 11hr round trip, no issues (mostly) life's great.
I clearly cursed myself by saying I had no leaks. I'm in my home city visiting my parents and I look at the rear tire. oil spray. nice.
a swipe of the finger, and its clearly rear diff oil.
Back home, I drove over to a well respected differential shop today. I simply asked 'how much for a full diff rebuild with bearings and clutches'?
I walked back to work, and walked back to the shop 5 hours later. Its all done but the crying (and paying for it).
They felt the burnt out clutches increased the end play in the axle taking out the seal. I have no idea, but I do know I now have warranty. I didn't even ask for the old parts....... how reckless is that? lol
- April 3, 2008
At least it is done and you don't have to worry about it anymore.
Afraid to ask, what does that cost anyway?
- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
Good trip home I expect to see family yes?
The rear labor costs have gotten very high all over in the last many years. What used to be a $200 job to swap gears is now $500 easily(in the 90's Mustang shops used to do the Mustangs for $100).
Setting up the gears properly is the special part, anyone can do any other rear work readily. I did my 98 truck's rear, and the rear bearings and seals(not the pinion), Severe Gear fluid, for around $75. I left the clutches untouched knowing I'd upgrade to a better diff.
- February 18, 2009
- 04 Mustang GT
$700.00
They caught me at a weak moment when I just wanted the problem to go away.
The good part is that I know the shop is very good, and all they do is differentials and manual transmissions.
- January 22, 2007
- selkirk, manitoba
lol, you have massive balls compared to me at the moment. i am still afraid to take a drive to gimili, and thats only 45 mins away! as for the diff bill, thats really not to bad. i think the bearing and seal kit it around 200, and the clutch pack kit is another $100. did you take it to asperline?
- February 18, 2009
- 04 Mustang GT
Yup, they are just down the street from work, so it was super easy for me.
I haven't tried out the limited slip yet. I really want to get the boost under control before I start hammering on it.
Interesting thing is, I have some amsoil gear fluid for the rear end, but they said they would not use it. Their experience is that synthetic fluid glazes the clutches. So, now I still have this expensive synthetic gear oil in the garage with no use for it.
- June 17, 2004
- Knoxville, TN
I haven't "inspected" the traction lok clutches of any of my cars, but they all have the Amsoil in them. I put the Torsen in my Mercury in 2004, and those have no clutches, thus no need for friction modifier either. I didn't use a friction modifier in my new 98 because I'm hoping to change the differential soon enough.
Most times the clutches are worn out for any Ford you see, they don't last very long unless the vehicle never sees hard use, gravel etc.
FYI, most times you can rearrange the clutches of the Ford LS, and end up with one more set on each side. Stock has three pairs, with steels doubled up in places. By removing steels and having frictions between each, usually four will fit. My 93 I did that with and it was very tight to fit the axles back in(the c-clips), but it fit and worked great. Those didn't wear out nearly as fast as my Crown Vic LS did before that.
The LS clutch kits used to be $50 from Ford(1999), and you have to have an extra set to be able to possibly fit the extra frictions.
Synthetic gear oil is required by OEM for the Explorer, so they all had it stock. It is no issue for clutches. You shop there may have been dealing with race applications where people are much harder on the rear gears and axles etc. Who knows, and in such cases those guys would be opening up their rear often, replacing with fresh cheap grease may be no big deal for them.
Ford and most synthetic gear oils are near $25 a quart. Severe Gear is $10-$11 per quart, plus shipping etc. It's also better.
- August 1, 2008
- MO MO
- 94 & 95 XLT's
Sorry you got the whammy. I just went through this last week myself, but had a carrier bearing explode, taking everything with it. I had to replace everything but the 2 axle shafts. I know the pain on this one.
Am I understanding this correctly? They did an LS kit & housing tube seals, and used Dino fluids?
Which bearings did they replace? Axle tubes, or Carrier? Did they reset the gears and use a master install kit with all new bearings and pinion crush sleeve? $700 for just the LS kit and seals is high, but if they reset the gears, and installed everything that comes in a master install kit also, $700 is a good price.
I agree with Don and the diff fluids 100%. Full Synth is best in my book. Using Dino fluids, be prepared to change it often, if your going to use this rig as I think you will. LOL!!
- February 18, 2009
- 04 Mustang GT
They installed all bearings (axle's and carrier), seals, and ls kit using dino fluid and that anti chatter additive that stinks so bad. I'm going to leave the dino fluid in there for now. I do have the synthetics and additive if I choose to make the change.
I'm guessing that they would have had to reset the gear lash also. They would have done the carrier bearings as they told me with age that bearing wears causing wear of the rear pinion seal.
Its super nice not leaving any signature oil spots on the ground any more.
I have the new waste gate in, and its controlling boost nicely. I have the boost controller backed right off, and have a total of 2 lbs boost max. I'll start turning up the boost with the boost controller over the next few days. Then I can get back to wot tuning.
- April 3, 2008
YES! waste gate is on now you can have some fun!
2 lbs is nice and low too, so you know it is working well.
Did you install the waste gate or did you have to take it to the exhaust shop?
- February 18, 2009
- 04 Mustang GT
I took it to the exhaust shop.
I could have bought an adapter that might have worked, but I had a down pipe that was randomly resonating on the frame that needed to be 'adjusted' anyway.
I added a spring to the waste gate for a couple of reasons.
1. fiddling with the boost controller knob, doing a wot run to check boost level, then re-adjusting knob can take a long tome to find the desired boost.
2. I was reading that a rule of thumb is that a boost controller should be used to no more than double boost on the spring(s).
I added a .3 bar spring to the waste gate and am now at about 6 lbs boost (opportunity to pass on the way to work today gave me a chance to test). Now I get to go back to #1 (above) to find a few more lbs boost.
- April 3, 2008
Have you looked into an electric boost controller/gauge?
Some have settings that can be memorized, and pushing buttons on the boost gauge would be a little easier than turning a knob.
You could have setting 1 as daily driver mode, then if someone comes along that looks fast you could go to setting 2 which might be called leave you in the rear view mirror mode. lol
Similar threads
- Replies
- 15
- Views
- 1,215
- Replies
- 10
- Views
- 2,404
- Replies
- 1
- Views
- 1,371
- Replies
- 6
- Views
- 1,021
