Turdle and Gmanpaint's Rock Slider Build Thread | Page 2 | Ford Explorer - Ford Ranger Forums - Serious Explorations
Turdle
Lowrider
Staff member
Moderator
Humboldt, KS
2000 Mounty
Gmanpaint's sliders are finished being built now, finally.
Tomorrow they will get a good coat of winkle black.
We have gone with a u bracket, so, no drilling required. This takes a while to mock up.
Turdle
Lowrider
Staff member
Moderator
Humboldt, KS
2000 Mounty
Turdle Works
--kinda has a ring to it.
Honestly, besides a lot of prep work ( flap discs are all that) , all I have done so far was drill the holes in the brackets, hold things--and speculate on building these as a bolt on kit. I wish I could take the credit for the fabrication.
I do think it is a go though, as, we have the issues worked out. Varying degrees of body lift will be the only hangup
Turdle
Lowrider
Staff member
Moderator
Humboldt, KS
2000 Mounty
wisekise
kentucky
1998 sport
very nice:thumbsup:
i wish i had time to build me a set. i have the 2x4x1/4 and 2.5x2.5x1/4 steel but no round tubing, and i need to figure out the mounting.
since mine is a 2dr could i get away with only 2 braces back to the frame, if built very stout?
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
Not to hijack the thread but yes - as long as you move them in closer towards the center (maybe a foot away from each edge of the slider). The reason is that 99% of the time, the obstacle will almost never impact near the slider's edge because the obstacles you'll climb over are not 90 degree ledges built out of concrete or bricks. So as the tire rolls over it, the vehicle is moving forward and so most of the scratches you'll see is closer towards the center than the edges.
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
Is there space to run a cross member between the frame rails, to strengthen the mounting brackets? Even one cross member near the middle where most impact would happen will help, for far outer edge impacts.
You might get away with using the OEM running board holes for the end mounts, that would simplify those. No, scratch that, if you ever dropped the slider on a rock next to the tire, the body wouldn't like that. I'd still make a frame mount at the ends also. The body mounting would be very helpful for the running board, step forces. I see some triangulated frame brackets in my head.
Turdle
Lowrider
Staff member
Moderator
Humboldt, KS
2000 Mounty
Drilling the front brackets, in line, was made easier by tack welding the 2 plates together--
My idea-:D
Turdle
Lowrider
Staff member
Moderator
Humboldt, KS
2000 Mounty
I wedged a couple chunks of metal in the middle and rear brackets , also to drill the holes in line
Turdle
Lowrider
Staff member
Moderator
Humboldt, KS
2000 Mounty
Then you should approve of this--:D
Turdle
Lowrider
Staff member
Moderator
Humboldt, KS
2000 Mounty
Here is a close up of the finished product
The goal was wrinkle black in visible areas, glossy on the hidden ones.
