Well, it is about time I do this
This is our 1998 Mountaineer.
We acquired it in late 2000, with 29 k on the odometer. Previously it prowled the Oklahoma turnpike as an unmarked police cruiser.
I would say it was about June-2001, when the initial madness set in, and I became obsessed with changing the looks.
I found Explorer Express, Where I scored the x-spec suspension.
After talking with John V., I learned of the Apten group buy here, and the rest is as they say, history.
In June of 2002, I acquired an exhaust leak. Being the expert I thought I was, I bought a header gasket set, went to fix it.
Well, in my thinking I didn't have the front bolt tight enough, I snapped it off into the head---ooops.
After pouting about this for awhile, I decided to really get into this site for answers.
The result--
347 cubic inch, stroked and bored engine
FMS sportsman block-bored .030 over and machined for stroke
Billet crankshaft with chev rod journals
H-beam ultra light rods
Probe PRS forged pistons -9cc dish ( slightly over 10:1 compression)
Melling stock volume oil pump
Edelbrock performer efi heads 2.02 intake, 1.60 ex valve 58cc chambers
Crane's roller lifters--billet aluminum lifter guides
Crane's roller rockers
comp cams pushrods
Cloyes true billet double timing set.
FMS X-303 camshaft, advanced 4 degrees
Professional products Typhoon intake and EGR elbow, with 1" phenolic spacer
FMS 42 lb injectors
Aeromotive fuel rails, boost reference regulator ( currently set to 43 psi.)
Walbro 255LPH fuel pump--return style 3402
Lightning MAF
Torquemonster headers--stock exhaust with rear cats removed--magnaflow dula in single out-Hooker Aerochamber stacked right behind, 3" mandrel bent MAC tailpipe.
Art Carr 3000 RPM flash lockup converter ( 10 " billet housing)
Art Carr built valvebody kit
Amsoil fluids in all otherwise stock components. ( since I change my oil early and often, I use the least expensive synthetic oil. Usually Amsoil, but sometimes I will use Mobil 1)
AWD IS OUT!! 4406 4X4 IS IN!
http://www.explorerforum.com/forums/showthread.php?t=166726
http://www.explorerforum.com/forums/showthread.php?t=185203&highlight=turdle
UPDATE
As of 2-17-08
I mentioned the truck being a poilice cruiser in it's first life-
well, this caused a little "glitch"
While the PCM says it is a NRT1 box code, somewhere along the line a police code was flashed into the PCM.
My original paperwork shows a dealer service call for a PCM reflash right before the title was signed over. I am assuming the police tune was recovered, and a stock tune re loaded.
However,
they didn't mention they loaded it with a MC2O box code.
After 2 trials with the initial run tune, I actually read the box code with the XCAL2 and James deteremined This error.
Once this was figured out-the tuning was ON!!!
Baseline tuning is complete and all is well. I'm waiting on a new Innovate LM-1 wideband for WOT tuning.
Somehow mine took a dump,
I spent a whole day trying to figure it out. If it had been operating though it would have been a breeze.
James ( jah81592) is about the best help a guy could ask for in this area.
www.hensonperformance.com
UPDATE 2
Tuning complete-after a few WOT pulls to 6000 rpm's
James has not only achieved a great tune in my truck, but totally eliminated the surging issues I was experiencing.
UPDATE 3
Truck now lifted for trip to Colorado Gold mine trails--page8
Update 4
colorado trip completed-Imogene pass and Black bear pass have been driven in this truck
woo hoo!!
picture of black bear pass-
update 5
On Sept 19, 2008 Went to KCIR and ran a 14.8 @ 90mph---2.002 60 ft time
I was snoozing and did everything wrong. It has more in it.
Update 6
After drooling over Mountaineergreen's extensive suspension mod list for years-
With a feeling of guilt, for not doing the actual work myself, I have acquired his
4" superlift suspension lift,
410 gears
aussie locker in rear
disconnect front diff--- http://www.explorerforum.com/forums/showthread.php?t=188359
double cardan front drive shaft ---http://www.explorerforum.com/forums/showthread.php?t=185232
285-75-16" cooper discovery sst (33") tires
UPDATE 7
Exhaust Dumps installed 4-15-2009
These allow the exhaust to be opened right after the cats.
new pics as of 3-16 2009
update 8
Added another stock trans cooler beside original, installed hard lines and twin 10" cooling fans
They seemed to work just fine
Update 9
Sliders installed!!!
http://www.explorerforum.com/forums/showthread.php?t=245321&highlight=sliders
I used Smoked chrome powder coat on front and rear bumpers, sliders, and wheels make for a factory look match
Bumper pictures are before slider install-
Next up--Get rid of torsion bar drop brackets, and, the bars themselves.
I also have some mild white neon tube rock lights, some very bright 55w rock lights, and, 6 rock llight of death tubes ( to be shown later)
stay tuned!!
The result--
comp cams pushrods
FMS 42 lb injectors
Lightning MAF
UPDATE
As of 2-17-08
However,
UPDATE 2
UPDATE 3
Update 4
woo hoo!!
update 5
Update 6
410 gears
UPDATE 7
update 8
Update 9
stay tuned!!
