cudabnu
- September 17, 2015
- Ventura, CA
- 2011 Explorer Limited 4x4
2011 limited, both left and right turn signals blink fast, hazards blink normally. Replaced both front dual filiment turn signal bulbs as the drivers side had a burnt out 2nd filiment for the running light, inspected the rear bulbs, then found 3 of the leds on the right side view mirror were not working, so just replaced that. After each change and testing I got the same result...fast blink on both left and right, hazards blink normal.
What else can I check? Is there a setting in forscan I can check out?
