Marvial
- December 26, 2009
- Gothenburg
- Ford explorer '94 and '00
My 2000 Limited started to act up a year ago or so, but the problem "went away". After reading up on the issues, I thought I would sort this out once and for all. But, no cigar...
Problem:
Turn signal AND 4-way flasher works OK. Every once in a while, the flasher relay starts to click in a random fashion. However, exterior lights or dashboard indicators are dark.
When the clicking starts, it quiets down if i brake. Sometimes it goes away. Sometimes it is there. This led me to suspect grounding issues....
On my Ex there is no "yellow relay" under the dash. Rather, 1 ft above floor, bolted to the steel frame inside the protective metal cover, there is a black Volta Flasher. It has five pins, and two wires OUT OF THE TOP, a blu / brown. The socket is 5-pin. Several threads mention SIX-pin.
The blu/brown wire seem to go to an indicator light next to the cluster dimmer switch, that flashes if I press the hazard button (as well as all 4 corners)
Rocking the indicator lever, sometimes I can cause the clicking to start. I took of the covers, removed multifunction lever, sprayed all connectors, it seems OK.
There is a cable harness to the left of the steering wheel with the two connectors for the
mulifunction lever. Rocking this harness does not seem to cause anything.
On the right side, there is a yellow tube harness. At first, when I pushed or pulled this harness, I could trigger the clicking.
I disassembled connectors above pedals, sprayed, reinserted a couple of times. Problem seemed to reduce, but was not gone. The other end goes to
1) ignition lock, small green connector. I could not disconnect, but I could rock it up or down by 1 mm or so, so I thought any oxide should have been displaced.
2) a couple of wires going into the steering wheel, I removed horn / airbag, but not steering wheel. These wires seem to go to cruise control buttons.
I listened my way to find the flasher relay. I cut the blue / brown wires, removed the relay, opened it up. It has i IC a couple of random components and two relays. I soldered all joints, especially those with the capacitors. I sprayed the board and cleaned with toothbrush, a very small sign of oxide.
All assembled again (except blu-bn wires). Everything works, but I still have random relay clicking.
I measured the 5-pin plug. Black wire is ground, 0.3 ohm to chassis, maybe 0.1or so from instrument leads. Out of the 5 pins, 3 have +12 V, two are ground (one the black)
Shifting the turn lever NOTHING happens, still 12 V on same 3 pins, 0 V on two. Putting the relay back all works, (but random clicking is not gone). I am out of ideas, I don't have any reasonable diagram, I don't have a yellow relay under the dash, but a black thing with wires out 12 " above my feet.
I am pretty sure it IS A 2000 EX Limited though....(could it be a VAZ in disguise?) Help!!!!
Edit: the blu/brown wires is probably an addon by the previous owner, since most original harness wires are 2-color, these are blue/brown which are standard
colors for "household cord" in Sweden.
*Wild Guess*: The indicator in the emergency flasher died. Rather than removing the lever and changing the bulb someone
mounted a small green pilot light on the dash next to the cluster dimmer, soldered wires in the relay, drilled two holes in the case and put the stuff back. It seems a very elaborate thing to do, but maybe you can confirm that *your* explore does NOT have a small green indicator next to the dimmer.
:exp:
Problem:
:exp:
