Turn signals flash once then quit | Ford Explorer Forums - Serious Explorations
chaingang
B'ville GA
98 V8 & 04 Limited V8 4x4
2004 limited, turn signals will flash once maybe twice then quit. Doesn't matter if your using left or right. The hazard flashers work and all the lights are good. I can hear the relay working under the dash and even the trailer, left and right, relays under the hood when the hazards are on. Switch on the column or relay? Are the turn signals on seperate relays from the the hazards and is the flasher relay on the back of the fuse panel? Owners manual says to have dealer service this relay. Rather do it myself if it is just a simple replacement.
