two hydraulic tensioners for timing chain | Ford Explorer - Ford Ranger Forums - Serious Explorations
rocket22
La Grange, IL
2002 Explorer xlt 4 wd
Tensioner question: If I just replace the two hydraulic tensioners for the timing chain, is there any probability the rattle will diminish on a 2000 4.0 SOHC with 165K miles?
The cost of the full replacement is not worth it.
Join the Elite Explorers $20 Get rid of the ads!
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
. First register on the forum, then join the Elite Explorers to get rid of the ads!
Flash
Brisbane Australia
1997 Limited
Yup, it's a possibility, especially if you only or mostly get the rattle at start up.
What happens is the tensioner allows rattle until the oil pressure builds up, during that time the chains thrash about and destroy the guides.
Stop the start up rattle and the guides will last longer.
But, the rattle in my XLT was in the intermediate chain and the tensioner for that is inside.
PLAPELLO
Chicagoland, IL
01 & 03 Explorer Sport
My guess would be, extremely low chance it would fix the rattle.
I did this job a few months ago and I could maybe see a tensioner being weak, but I don't think there would be any rattle due to one of those 2 being faulty. The tensioners hiding inside the timing cover are more than likely the causes for your rattle due to the originals being somewhat weak.
Mine ended up being the Balance shaft tensioner which I was not prepared for. But this thread helped me a ton:
http://www.explorerforum.com/forums/showthread.php?t=269442
rocket22
La Grange, IL
will towing shorten its life?
I am going to drive this pos work truck until it croaks. Will towing put any additional pressure on the rattling chain?
BubbaFL
Central Florida
1986 Corvette
Depends what rattle you have.
If you have startup rattle that goes away when oil pressure comes up, it might help.
For 2500 rpm "pinging" type rattle, it probably will not help.
If your truck's engine sounds like a diesel at idle, forget about it.
nitrodude
97 ford explorer
Wondering this same question. Mine rattles at startup for the first minute or so then stops. Was wondering if I replaced one or both of the tensions if it would stop the rattle.
Truck has unknown miles. Odo stopped at 175k before I bought it. Unknown maintace done.
Seems to be a strong running engine and trans sea to shift good just a bunch of little issues I've been fixing.
Don't want to spend the $70ish for the tensioners if If it won't help. Already spent a bit more then I wanted to on it.
nitrodude
97 ford explorer
Well. Guess ill find out if it helps or fixes it...just ordered both tensioners for $120 from advanced auto.
I might have to buy a deep well 27mm socket and a long 1/2" extension if I can't find one here.
