I have a pair of brand new U-bolt and shock skid plates specifaclly made for the rear of a 1st or 2nd gen Explorer. They are 1/4" plate and protect your u-bolts and raise the shocks up a few inches. These are made for 5/8" U-bolts which are bigger than the stock ones so if you dont have 5/8" ubolts now would be the time to upgrade. These may cause shock to swaybar mount interference so shocks should be mounted body side up or if you have removed the rear swaybar it is a non-issue. Also note these raise the shock up 2"-3" so shock length could be an issue depending on your lift and shock length.
Current price for a pair is $215 shipped to the US due to the high cost of steel right now.
