- September 1, 2002
- Lake View Terrace, CA
- '91 Navajo '99 X '19 Rngr
Alrighty! I will fully test these tomarrow in Big Bear.
First this one was done on a '99 explorer in the rear. So it should work on all I think (exsept 4 dr 02+)
I started by buying
*two 7/16"x 3" studs with pre drilled holes (not sur what there called but there like a bolt with no threads and 5 or 6 holes)
*six 3/8's washers
*two pull pins.
Unbolt the links from the sway bar and frame. You will notice the bottom bolt is pressed in. The top has a nut which has a frame clip, pop it off. Flip the link over and bolt it in to the frame using the exsisting hardware from what was the bottom. This will be a little of a pain and you probbaly need a washer for a spacer being that the bolt isa bit to long. After bolt in up the bottom hole should match up as before. Now take your stud slip on a washer slide it through both link and sway bar. use two more washers for spaceing and put in the pin.
There you go! Quick discos done cheap!
I started by buying
*six 3/8's washers
*two pull pins.
