allmyEXes
- February 6, 2016
- No. Alabama USA
- 1997 Blue Ex 4.0 SOHC
- Callsign
- KAGG 3611 (CB)
I'm old enough that I learned how to drive in a 1954 F100 with 3 on the tree, a wore out clutch and a long wore out steering and suspension. I learned how to be a Mechanic and more working on '60s Classic Mustangs. Automobiles and trucks have changed a lot since them. Now I'm not old, old by any means, but I'm not 24 anymore either.
Last summer I used PontiSteve's online service to have PATS deleted from my 1999 Ranger PCM before I started messing around with the Ranger wiring. Cutting this, deleting that and the fact that I'm not using the Ranger column in my '54F100/99Ranger project.
But today, I have the 2002 on my mind and I want to delete PATS on it as well as another vehicle. And I might want to purchase junkyard PCMs from time to time out of 1998 and newer Fords. It would be handy with the proper tool kit to see if the donor PCM is good in the first place, delete PATS and perform other custom PCM tuning. Below is a picture of the tools that PontiSteve used to work on my Ranger PCM. I know that there is info deep somewhere here on the Explorer Forum but searches haven't produced good results. I also know that there is at least one or two of y'all on here capable of doing PCM manipulation. Below is a picture of Steve from Ocala's tools. In my limited knowledge of all of this, I can identify some of the components. The top left is a 12-volt power supply running at 13.2 volts. Next to it is a capable Laptop. Next a J2534 programming tool? of some sort. The bottom row is a PCM that is being worked with and the last piece or two looks like to me, a home-built interface box with cables plugged in to it. Now I will admit that I have very limited knowledge of how all of this works, so be patient with me as I learn and collect all of the neccesary pieces.
I have two power supply options one of which is a homemade 12-volt PS that Dad made back in his past days, and a 12-volt PS out of an old desktop PC. If my EE Dad was still alive, he would be up for the challenge, because if is electronic, he would want to know how it all works together. Here is the picture.
Feel free to help me along including links to 'how to' and equipment. I will be purchasing a new Laptop to do this so that I can do this at home or work and with the PCM in the vehicle or not. Thanks guys and gals.
