XLTrunner
- April 19, 2015
- MN
- 1998 Explorer XLT 4.0SOHC
In my effort to determine my options with my ignition key issue posted on another thread, I've been trying to understand exactly how PATS works among the various integral components; i.e. chip key, transceiver ring, control module and PCM. Digging thru old threads on here seems to confirm few people really understand how the process is carried out. I found this article online that seems to explain it better than anything I was able to find.
Ford PATS Antitheft System — Ricks Free Auto Repair Advice
If I am to understand this article, the PATS control module is what ultimately confirms the chip code and then sends the "go ahead" signal to the PCM for activation of the start & run process. If that's the case, could a person take the cylinder lock w/key, transceiver ring, and PATS control module from a donor vehicle of same year/model, and simply swap them into their own vehicle and the PCM would accept the signal to start the vehicle without having to be re-programmed? Hoping someone on here has some extensive knowledge or experience to confirm or dispute this.
