lgExplorer11
- September 13, 2015
- Henderson, TN
- 2011 Ford Explorer XLT
At the end of April, I took our 2011 Ford Explorer XLT 150,000 miles to Lonnie Cobb Ford, Henderson, TN, because the engine was overheating and I needed the Works Package ($41) done. The water pump and timing chain had been replaced in August 2018. I explained that I had another shop replace the thermostat and that here was no air bubble in the system, as I had looked up online and found a video made by a Ford mechanic on how to eliminate one if there was one, but the engine was still overheating. I received a phone call later that day from the service center and was told that the cooling fans and the cooling fan module were bad and had to be replaced. I told the man at the service center that the fans were checked by myself and a mechanic, and they were working. The man at the service center said that, yes they worked but they would not speed up when the engine got hot. He said they had checked the engine codes and they said to check cooling system, which meant the fans. He told me they idled the engine for an hour and a half, and it did not overheat, so the problem had to be the cooling fans and cooling fan module were the problem. The cost would be a little over $900 with the Works Package included. I am a disabled veteran, my wife is also disabled and I have a set income. We desperately need the vehicle to make our doctor appointments, so I called the service center business office to see if I could set up a payment arrangement. After that was done, I gave permission to make the repairs.
After getting the Explorer back, the first trip over 20 miles resulted in the engine once again overheating. I drove it back to Lonnie Cobb Ford, stopping a few times to let the engine cool down, and let them know it was still overheating. I called the next day and they had no figured out why it was overheating and that they had escalated the problem to Ford. I called the next day and was told that Ford had said the problem was either the water pump or a clogged radiator. I once again told the service technician the water pump was replaced in August 2018. Later that day, I received a phone call that the Explorer was ready to be picked up. I asked what was wrong and was told that it was a clogged radiator. So I called another Ford service center, Golden Circle Ford, Jackson, TN, explained the situation and was told the price of a radiator flush is $159.99.
I wrote a letter to Lonnie Cobb Ford disputing what I had been charged and waited a few days for an answer, because the manager's wife was in the hospital. I finally received a call from the service center and was told that they had worked on the Explorer for two and a half days after I brought the Explorer back. I was told the first thing they did was to vacuum fill the coolant system (unnecessary because there was no air bubble) and that was not what I was originally told before replacement of the cooling fans and cooling fan module. He then said they replaced the new thermostat that had been installed by a friend of mine who is a mechanic, but that also did not work so they escalated the problem to Ford. He said that he knew I was disabled, but there was nothing that they could do because replacement of the cooling fans and cooling fan module was the mandated repair by Ford for the check cooling system code. He let me know that none of the work they did after the Explorer was returned to them was charged for. So I have been billed for a very expensive unnecessary repair that is mandated by Ford instead of the simple radiator flush that was needed.
I would like to know who I can contact at Ford to ascertain if the unnecessary repair is indeed mandated by Ford (and why), or if Lonnie Cobb Ford service center is trying to avoid having to absorb the cost of making an unnecessary repair.
