mbruffey
- March 21, 2006
- MN, MN
- 1997 5.0 AWD Eddie Bauer
1997, 5.0, 75K.
Today I disconnected MAF, but first:
I have had a problem with rough idle and somewhat rough/erratic shifting for about a year now, I suppose. Idles rough--noticeably but not severely--most of the time, cold and hot. Improves some days, especially damp days. I drive gently, but upshifts roughly even on mild acceleration. Tends to "drop" up into 3rd gear abruptly if near shift speed and decelerate at stop sign, say 20 mph. Used to upshift religiously around 2000 RPM, but now holds until say 2100-2200. Sometimes start-stall when hot, but not very often. Light pressure on accelerator usually starts it. Tailpipe is nice and brown (not black) inside. Exhaust seems to have a deeper, throatier thrumming than it used to, but this varies with performance. Downshifts earlier than it used to, when I call for power or climb a hill at moderate speed (30mph). More recently, noticeably downshifts 3-2 when descending a hill and slowing/braking. NO CODES. NO CODES.
Actions taken (none resulted in noticeable/permanent improvement):
*Replace Plugs and Wires
*Replace Fuel Filter
*Replace Fuel Pressure Regulator
*Clean IAC
*Clean MAF
*Measure TPS Resistance / Travel
*Deoxit TPS and ream holes reinstalling slightly CW in case flat/dead spot.
*Fresh Silicone Grease on Sensor Connectors mentioned above
*Check Battery Voltage (12.5 off; 13.8 running)
*Clean Air Filter
Today:
Disconnected MAF and drove home (6 miles):
*Idle smoother, but not perfect. Roughness of idle different in character; hard to explain.
*More power accelerating from stop, but I did not push it.
*No more downshift climbing hill at 30-35mph.
*Shifting overall exquisite, except a little rough 1-2.
Conclusions [from today's MAF experiment] (correct? you tell me!):
NOT EVEN POSSIBLY the Fuel Pump, since fuel pump clearly can deliver.
NOT LIKELY A Vacuum Leak, since character of rough idle changed and acceleration/power returned.
NOT NECESSARILY MAF, since disconnecting MAF "disables" many other sensor to computer signals.
NOT LIKELY Tranny, since shifts fine (except 1-2) w/MAF disconnected.
NOT LIKELY Bad Gas. Disconnecting MAF unlikely to improve.
NOT Ignition. Tailpipe would be black; would run worse damp days.
What's happening? My working hypothesis: Computer "thinks" engine is running rich and is leaning it out when MAF is connected. NO CODES.
Am I right? Wrong? Talk to me! I need a strategy so I can poke at the most logical spots in the most logical order.
What is it? Why no codes? Possibilities:
*Knock Sensor? Where's that located?
*Temperature Sensor? Where's that one, too?
*Bad MAF? Noticed ends of one wire inside are browned. Backprobe? Expected Voltages?
*O2 Sensors?
What?
Thanks, LMB
*Clean IAC
*Clean MAF
*Clean Air Filter
Today:
*O2 Sensors?
What?
Thanks, LMB
