(Update) Windows won't roll down, need help. | Ford Explorer Forums - Serious Explorations
302Xplorer
Richmond,Va
'00 XLT
Found the culprit. Looked at eh fuses again, it was the one in slot # 26. Replaced it and the windows work again.
No, the window "lock" button is not on.
I have already removed the driver's side interior door panel and checked the wiring and nothing jumped out at me.
Looked at the fuses, none blown. Although I do not believe the windows are on a fuse.
Can someone point me in the right direction?
Thanks in advance,
302X
check the wiring going from the door to the body, i had this problem about a year ago and thats where i found the problem
Could you describe the problem that you found?
i didn't find it Ford did, I had the same problem except mine went down and would go back up and I did the same things you did, took it to ford and on the recepit it said found a shorted wire in bundle from door to body
Dome light help (pics)
oops
