Updating SYNC Image Loop
Jamicsto
2014, Explorer Sport
So I just recently bought a 2014 Explorer sport. Being a techy one of the first things I wanted to do was update MFT since it was still at the same version that came out of the factory in 2013. I went out to Ford owner site, entered my VIN and it told me there was an update available. Downloaded and extracted it to my usb drive went out and started the vehicle and started the update. At some point during the update the screen went black which I read was normal. After about an hour and fifteen minutes it was still black. I shut the car off and now the MFT boots to a screen displaying "Updating SYNC Image", "Waiting for USB Device" is displayed along the bottom. After a minute or two, "No USB Device Found, Canceling update" is displayed and the process restarts. I've tried disconnecting the battery cable to no avail. Anyone had this issue? If so, were you able to fix?
Thanks.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum.:wave:
Just want to clarify one thing. When you downloaded the update did you download it to your computer first and then to the USB?
Jamicsto
Yes. Then extracted it to the root of the usb drive using 7zip.
peterk9
Staff member
Moderator
Callsign
VE3
See this post and the 2 following in another thread; MFT Update V3.10
FYI, I have never unzipped any files. I think I only had 3 files on my USB.
System Volume Information
autoinstall.lst
DONTINDX.MSA
Now the above are from a Sync 3 update but I'm quite sure they were about the same for my MFT update.
jmr061
Wisconsin
16 Exp Sport
I don't recall a user fix being available for that. A dealer will have to update it if it isn't damaged beyond repair. Your vehicle may still be under program #12M02 which is a 5 year warranty on the APIM. If the vehicle in service date is at 5 years or less it would be covered. Better contact a dealer ASAP. Hopefully your vehicle warranty started later than 1/24/14. If you send me the VIN via message I can check it rather quickly as well.
Jamicsto
Just replying here since I’m always running into forum posts with no updates/resolutions...
I did not get this fixed. I had been contemplating doing the sync 3 upgrade kit from 4dtech and this pushed me over the edge. jmr061 checked on the 12m02 and it was expired.
