Upgrade Torsion Bars?
Mr Medo
Burlington, Ontario
'96 XLT V8 AWD
Code "A" torsion bars
Great site and great information. I know this is an old thread but I am about to change my torsion bars to something stiffer. Reading all the posts above I get the impression that the stiffest springs are 1 then 2 then B all the way to L. I have a 4 door '96 XLT 5.0 V8 and the door jamb sticker says spring code "A F". The 3 layer rear leafs should be the F so the torsion bars must be "A" yet nobody has mentioned the "A" before. The factory stickers around the torsion bars are Drivers Side - F67A-FA LFA (yellow sticker) and the Passenger Side - F67A-FA RFA (white sticker). Can anyone tell me which springs are stiffer than my "A's"? My dealer says they have no information on spring rates.
Thanks.
cmax13007
Michigan
'01 Sport (2dr)
Sway bars from 95-97 are the same, Hollow front and back. 98- 01 have a solid front bar and a hollow back bar.
T bar ratings range from 1,2 A, B, D , E , F (I think those are the right letters). 1 being the stiffest, F being the softest. I'm not sure how the t-bars were distributed throughout years/models/options though.
Whats up fellow X Owners,
I am currently looking to find a new set of Torsion Bars. I asked the local dealer and they said all he needs is the last 8 digits off the VIN of any vehicle to find the spring rate.
I took the last 8 digits off a 4 Door V8 sitting at the local junk yard. I called up the ford dealer and he said the spring rate was "2". See list above for spring rates, 1 being the stiffest and F being the softest.
~CMAXXXXXX
Mr Medo
Burlington, Ontario
'96 XLT V8 AWD
~CMAXXXXXX
What year was the junk yard 4 door V8?
rwenzing
Michigan
03 Ranger FX4 LII 5.0 S/C
Thanks.
The #1 bars are stiffer than the "A" bars or the "2" bars and they are the highest rate available from Ford. They are used on some Ranger 4x4 Supercabs and are a direct replacement for 95~2001 Explorers. Here are the part numbers:
F67Z-5B326-FA
F67Z-5B326-FB
Last time I checked, the dealer price was about $55 per side. Online, around $40 each (plus shipping).
cmax13007
Michigan
'01 Sport (2dr)
T bar ratings range from 1,2 A, B, D , E , F in order. 1 being the stiffest, F being the softest.
CMAXXXXXX~
Jestifer
Burlington, Vermont
'03 Ranger Edge
:usa: Do the sport-trac and ranger have the same suspention up front? I know the FX4 use heavier bars, how about the edge?
I am having a really hard time finding quality lifts out there for late model rangers. Any help? I know some of you run the superlift 4", how do you like it?
Jesse
rwenzing
Michigan
The torsion bar rate is computer selected on the assembly line based on vehicle configuration and option content.
All FX4 LII Rangers use the strongest "1" bar. A 4x4 Edge could have either "1" or "B" bars depending on how it is equipped. The "F" bar is used on the lighter Rangers such as the 2WD regular cab Edge.
Jestifer
Burlington, Vermont
'03 Ranger Edge
Good deal. I'll see if I can find out what it has. Thanks for the help.
rwenzing
Michigan
Just read the spring code on the cert label on the door jamb. The torsion bar code is the first digit and the leaf spring code is the second digit. My Level II has "1C" which is the highest rate torsion bars and highest rate leaf pack available on Rangers. Later Fords (2004+??) use a digit for each corner, so the equivalent LII code for newer Rangers would be "11CC".
Jestifer
Burlington, Vermont
'03 Ranger Edge
I looked at the code last night. 1C, so I guess I don't have to worry about the tbars or springs being too weak. Did you do a 5.0 swap in yours?
studd469
Toronto, Canada
1997 Explorer Limited
Hi all, I know this is a t-bar thread, but does anyone have the part number for the pork chop looking thing on the end of the Tbar?
rwenzing
Michigan
fex98
Crestmead logan QLD
98 explorer 4x4
torsion bar after market
G Day mate
I would to like to by non genuine torsion bars. mine are soft and can not buy any in australia all I can get new one from ford :thumbsup: :thumbsup: regards Darren
becker69
Centennial, CO
01 Sport Trac
Do you mean the tortion bar hanger? I love pork chops :D
Jestifer
Burlington, Vermont
'03 Ranger Edge
I was looking at the 2-3" lift from fat bobs garage. It adds a leaf in the rear and uses a different t-bar hangar in the rear (i'm assuming to crank it up). Does anyone know if this will put too much stress on the t-bar??? I have code "1" bars in it, so I can't get a stronger one.
masospaghetti
Huntington Beach, CA
98 XLT, OHV, 4D, 4x4, 5M
Mine say F57A, could anyone tell me what stiffness these are?
V8BoatBuilder
Transplanted Bostonian
East Brunswick, NJ
97 Mountaineer V8 4x4
Torsion bars are now up to $90 EACH!!
Anyone have a better source?
volver
Milan, IL Quad City area
1998 XLT AWD
My explorer has "1" grade springs. They are saging on the driver side. I would like to replace them. Were can i get them for cheaper than 90 dollars?
Is there anything that i can buy to help saging after i do a TT. Maybe coilover shocks?
Trckmagik UPGRADE YOUR TORSION BARS Shocks, Suspensions, Lift Kits 6
R Rfoley22 Un-conventional Suspension Upgrade Project Shocks, Suspensions, Lift Kits 12
B Tie rods scraping body panel underneath feet after Bilstein shock upgrade. Shocks, Suspensions, Lift Kits 6
C Leaf Spring Upgrade for '98 Sport Shocks, Suspensions, Lift Kits 5
P need some advice on sas or fix/upgrade stock Shocks, Suspensions, Lift Kits 2
E Good shock upgrade... Shocks, Suspensions, Lift Kits 5
P radius arm upgrade ? for a 91 4x4 Shocks, Suspensions, Lift Kits 5
D DBR - Ranger/Explorer Clevis Steering Upgrade Shocks, Suspensions, Lift Kits 0
F Shock Upgrade for Better Ride Shocks, Suspensions, Lift Kits 16
V Suspension Upgrade or just fix it Shocks, Suspensions, Lift Kits 0
F Towing / Rear Suspension Upgrade Options? Shocks, Suspensions, Lift Kits 6
S Rear axle hydrolic dampener upgrade Shocks, Suspensions, Lift Kits 0
0 Camburg 98+ 4x4 Upgrade Installed Shocks, Suspensions, Lift Kits 27
S Please provide advice with an upgrade. Shocks, Suspensions, Lift Kits 2
D D35 - D44 TTB upgrade! Shocks, Suspensions, Lift Kits 3
gage DANA 35 UPGRADE Shocks, Suspensions, Lift Kits 2
T What to upgrade to? Shocks, Suspensions, Lift Kits 1
J '99 Explorer Sport 4x4 shock upgrade? Shocks, Suspensions, Lift Kits 9
I '99 Sport Rear sway bar upgrade Shocks, Suspensions, Lift Kits 0
Diff Whack Daddy Cheap front sway bar upgrade for superlift Shocks, Suspensions, Lift Kits 4
L Why do I need to buy torsion keys? Why not just crank bolt? Shocks, Suspensions, Lift Kits 2
T Bent torsion bar adjustment bolt Shocks, Suspensions, Lift Kits 10
B Is this the correct size for longer torsion bolt? Shocks, Suspensions, Lift Kits 1
B Do I need longer shocks if I adjust 1/2" Torsion bars? Shocks, Suspensions, Lift Kits 3
N I need help doing the torsion twist. Shocks, Suspensions, Lift Kits 8
R torsion keys and shackles Shocks, Suspensions, Lift Kits 0
9 torsion bars Shocks, Suspensions, Lift Kits 6
sport97 Torsion Key Question Shocks, Suspensions, Lift Kits 2
R Airbag torsion bar adjustment. Shocks, Suspensions, Lift Kits 2
5 Anyone have 34x10.50s with a torsion twist? Shocks, Suspensions, Lift Kits 4
I how to change torsion bolt Shocks, Suspensions, Lift Kits 1
S Does doing a 2" torsion twist without rear shackles look bad? Shocks, Suspensions, Lift Kits 3
duncanNidaho Torsion Twist problems (2WD 99 sport) Shocks, Suspensions, Lift Kits 4
C does a 1991 2 door sprt explorer have a torsion twist bar?? Shocks, Suspensions, Lift Kits 3
K small torsion Shocks, Suspensions, Lift Kits 1
G torsion bolt specs Shocks, Suspensions, Lift Kits 0
Y Torsion Twist different height measurements! Shocks, Suspensions, Lift Kits 0
S I did the torsion twist, and now I have a problem with the shocks. Shocks, Suspensions, Lift Kits 19
S Truxxx 3" Front Torsion Keys & Pro Comp Rear Add-A-Leaf Lift Kit Shocks, Suspensions, Lift Kits 15
GJarrett Torsion/Coilover Conversion Shocks, Suspensions, Lift Kits 150
T So I did a Torsion Twist Shocks, Suspensions, Lift Kits 11
T Longer Torsion Bolts? Shocks, Suspensions, Lift Kits 2
storlied Torsion Bolts Shocks, Suspensions, Lift Kits 34
storlied Torsion Bolts Shocks, Suspensions, Lift Kits 12
N Springs and Torsion bar upgrades. Shocks, Suspensions, Lift Kits 13
9 Torsion twist for dummies! (pics included) Shocks, Suspensions, Lift Kits 199
Glen4X4 Quest on the torsion/shackle link Shocks, Suspensions, Lift Kits 3
W Goodbye Torsion Bars Shocks, Suspensions, Lift Kits 69
wisekise torsion bar lift Shocks, Suspensions, Lift Kits 2
J Torsion Lift for a Ranger Edge Shocks, Suspensions, Lift Kits 0
Similar threads
