Mathematics
- June 18, 2012
- 2003 Mounty
First - have been lurking around here forever, tons of reading & useful info I've put to use on my mountaineer, so thanks for the resource here.
I'm a newb to car audio but have been upgrading the factory audio system, so far have completely sound deadened the doors & floor (fatmat, CCF, MLV), installed Infinity 8602's in all 4 doors, replaced the factory 8" sub with the shallow mount Pioneer 8", and also dynomatted the factory sub enclosure to try to stiffen it up a bit (thanks to JoeDirt & jrford's threads here for guidance on messing with the factory sub/enclosure).
Next time I'm home I'll also be installing a Pioneer 2400BT headunit and Kenwood XR-5S 5-channel amp to power the door speakers & sub.
The xr-5s puts out 350w RMS for the sub channel, so upgrading the sub to a 10" is now also on my list. I am set on retaining the factory look, so the sub/enclosure needs to fit behind the trim still. I'm looking at either another shallow mount sub and modding the factory sub enclosure to fit, or building a new sub box all together to try to make use of the space the factory amp takes up.
Any suggestions for a shallow 10" sub that can make use of all 350w? I was happy with the Pioneer 8" shallow mount, so looking at the 10" big brother...Is there a higher quality shallow mount sub someplace? Also, if I went the path of building a custom box with 3/4" MDF, could I fit a sub with a 5" mounting depth (Looking at Polk mm1040)? I've searched and found enclosure plans for 2nd gen but nothing for 3rd gen on here.
The other area I'm unsure of is installing a component system in the front 2 doors. Looking at Polk MM6501 6.5" set but not sure where to put the tweeters where they'll both sound good but still be fairly discreet...would mounting the tweeters in the door near the 6.5" be too low? I want to get the most out of the component system but don't want the tweeters to visually stick out.
Thanks for any help or suggestions. I work remotely so trying to get things lined out before I get home.
