While looking to find a set of good used seats to replace the basic cloth ones that were worn out I discovered there are not many good used ones around. They all tend to wear the same so I started looking at leather power ones.
Pick-n-pull had a half price deal on that weekend and I got a set the correct color for only $24 ea. If you decide to do this take a 12V drill battery with you and a couple of two foot pieces of wire you can use to move the seats fore and aft if needed to access the rear mounting bolts. Remove the sill plastic to gain access to the wiring and cut the two wires from the main harness first.
Remove the four mounting bolts and they are out. Don't forget to also get the section of wiring with the plug on it.
I found in my 97 that there is a good power lead in the drivers side harness but not in the passenger side. There are some smaller wires hot in the passenger side but not enough to run the seat properly. I spliced in only on the drivers side and ran the wires under the carpet from there to both seats. Sorry it was some time ago and I don't remember the wire color. Also, I just used a self tapping screw into the floor for the ground wire on the pass. side. And yes I know I should have taken pictures but at the time I was in a hurry and didn't think of it.
