Bobs2018ExplorerSport
- February 4, 2019
- Location
- USA
- Livermore, CA
- 2018 Explorer Sport 4WD
- Callsign
- KD6ANY
My 2018 XLT came to me with only some fairly basic options; an example of this was that in the rear cargo area, there was only a single "power-point" socket installed in the LH rear side panel (see pic). I wanted to "upgrade" that option to something that maybe offered a couple of USB ports as well, but I never really found an easy answer to that... that is, until recently.
I stumbled on this unit being sold on eBay, that not only offers the usual "cigarette-lighter-style" of socket, but also a dual-USB port, plus, a digital voltage meter... all in one unit. Additionally, the voltage display, as well as the lighter socket AND the USB ports, are all backlit, which is a nice touch. Here is the current link to the Seller that I got it from:
https://rover.ebay.com/rover/1/711-...0001&campid=5574912417&icep_item=253135717714
To make this conversion, I pulled-out the LH panel only enough to get my hands behind it, and removed the factory outlet and plug. Using a 1-1/8" hole saw, I then cut two more matching holes on either side of the original hole. This allowed me to mount the unit over the original location; I then followed the included wiring instructions, and connected it all to the original pair of power/ground wires that used to go to the single outlet.
Because the voltage-monitoring guage would hypothetically always be drawing low-level current once it's connected (as it displays the line voltage), you would think you'd be at risk of running the battery down eventually. Fortunately, however, all of the vehicle's Power Point outlets are pre-set (through ECM software) to eventually time-out. The length of time that the unit is "hot" seems to depend on if the car was originally "running" for a while or not, with something plugged into one of these Power Points, but it could allow phone charging up to an hour, possibly.
Anyway, this panel is incredibly cheap (only about $13 shipped), and its size makes it an ideal fit on the panel's ledge that had the original socket on it.
Check out the pics, and let me know if you have any questions.
