Upper Control Arm /Ball Joints | Ford Explorer Forums - Serious Explorations
tmbfi
cleveland, ohio
'92 4.0
I have a '97 Explorer AWD with 170,000 miles on it.Took it to my mechanic and he says I need upper control arms and upper ball joints to the tune of $600. Is this a job I can do myself?
prob not because u need a ball joint press... im having mine replaced right now for $447 so shop around and see if u can find better then that
The upper balljoints are permantly mounted to the upper control arms.. They are not cheap but can be done by yourself. You just need to get an alignment afterwards.
You should be able to do it yourself.
The upper control arms come with the ball joints installed. The driver side control arm is a pain in the butt because of clearance issues with the bolts but you just have to be patient. The passenger side is a snap, its a 2 piece design. you only have to replace the adjustable part of the arm not the whole thing.
I used Moog ball joints, they are lifetime guarantied and have grease nozzles.
I did my lower ball joints and upper control arms (incl the BJs) using this excellent post:
h**p://www.f*rd-tr*cks.com/forums/showthread.php?t=364301
I got a loaner lower BJ press, and 32mm spindle nut socket from autozone that worked like a charm. No other specialty tools were required. You need a good 3-4lb hammer. Didn't use a pickle fork anywhere, just some light (literally) tapping with the BF hammer as the post talks about. Also, I did pick up a good quality used Ingersol Rand electric torque wrench (thanks craigslist) to help get off the spindle nuts, but I could have used a breaker bar; it's just more fun to go pbbbbllblbllllll-rap-rap-rap with the torque gun! Didn't have to use any PB blaster anywhere thanks to the West Coast.
I got the lower BJs from rockauto $27@ (greasable MOOG) and the upper arms from autozone $70@ (TRW identical to originals with integral ball joint). There was lots of play in my lowers, and a very very little in my uppers after 120,000 miles, so I decided to use TRW uppers rather than the more expensive MOOGS given the wear pattern and the fact that I am cheap. (That said, the nice thing about the MOOG upper C-Arms is that the upper BJ alone can be replaced separately in the future without the hassle of R&Ring the control arm)
Separating the spindle (steering knuckle) from the upper BJ required a bit of whacking with the BF hammer once the pinch bolt was off, but the only thing that really sucks about replacing the upper C-Arms is that you have to make room to get the bushing bolts (and the camber plates) out by moving/shifting a bunch of brake lines. The lowers were pretty straight forward using the loaner press. I think I spent more time battling the frickin cotter pins than any other single thing :) You might want to splurge on a cotter pin puller..... Don't forget to wait until the front end is down before tightening the upper c-arm bolts otherwise the bushings will be miss-aligned and fail prematurely. Then it's off to the alignment shop or the stealer. ( In my case it was the stealer for the $29 coupon special)
If you've got the spindles off you should consider doing your tie rod ends too, or have a very good look at them.
Timewise it was about 3 hours on the first side and 2 hours for the second including cleaning up my brakes. The job is not all that complicated but takes a bit of grunting and groaning.
- James
