Upper Control Arms & Moog K80065 | Ford Explorer Forums - Serious Explorations
Clutchless1995
Alexandria, VA
1995 XLT
1995 4wd XLT. Replacing Upper Control Arms and using the one piece right side design. Got the Moog K80065 Caster/Camber adjusting cam bolt kit based on reading stuff here. Do these bolts just replace the factory upper control arm bolts on each side? Thus allowing a greater range of adjustment than the Ford bolts? None of the information online states anything about installation and although it seems obvious, I want to be sure.
I just did mine and I snapped the factory camber ajustment bolt and got the kit you are talking about and yes it replaces the factory bolt. It is shaped differently than the factory bolt mainly for better alignment.
Yes the moog kit replaces the stock bolts/wedges.
