Desert_AIP
- January 25, 2017
- 1998 Explorer XLT 4WD
I want to replace the radiator hoses on my 1998 XLT with 4.0 liter SOHC engine.
There are clearly four hoses on the engine, but I can only find three by searching.
There is:
Lower Hose, from radiator to water pump.
Motorcraft KM3399
Bypass Hose, from under thermostat housing to engine.
Motorcraft KM3269
Two-piece Upper Hose (this is where I am confused)
There's one piece from the thermostat housing to a metal curved pipe near the alternator.
There's a second piece from the other end of that pipe to the radiator.
When I search, I see "upper radiator hose" only. Not two different parts.
Motorcraft KM3043
Do I cut this hose in the middle?
Or am I searching for the wrong nomenclature?
Does the piece to the engine have a different name than "upper radiator hose"?
Help would be appreciated.
Part numbers would be awesome.
Thanks
There is:
Motorcraft KM3399
Motorcraft KM3269
Motorcraft KM3043
Thanks
