BeSkywards
- August 12, 2017
- '16 Explorer XLT
Hi, I've been searching this forum for an information on upsizing tires without changing factory 18" rims. I haven't found a definite answer though, so here's a precise issue.
I'm feeling 245/60/R18 wheels look a bit to small for Explorer. I've previoulsly owned 2003 explorer and after fitting larger A/T tires to original rims it looked way better, so I decided to do the same with the new car. Tire calcutator shows 265/60/R18 as an tolerable equivalent to 245/60/R18 and so the side wall of the tire would be 6,3". Having this checked with a measure on the car it should give the wheel more proporional look. The difference is the tolerable limit of 3%.
Alternatively, I could go with 265/55/R18 but the result will be less visible. Some of Explorer owners reported increase wear and defects of axle/drives and power distribution since the computer isn't programmed for a wheels different that factory approved sizes
And here's my question: can I fit a larger tires (meaning the same 18" rim but the higher sidewall) without making the car prone to damages? If yes, what's the biggest tire I can fit with 18" rim without problems? Or maybe I should leave it as it is for the sake of sound ride.
