FHP89LX
- March 10, 2004
- Sierra Vista, Arizona
- 2010 Mercury Mountaineer
**Urgent** 2000 Explorer 4.0L OHV. NEED HELP **Update**
Hi,
Please by aware this is my Daily Driver vehicle and it's down at this moment.
UPDATE WITH MORE PICS ON POST #4
My Explorer has 172K and I was getting a code PO305 # misfire. I search on the forums for days until i found the problem. I already replaced, wires, plugs, coil, cleaned IAC. Then I needed to replace the Intake (plenum gasket) Manifold gaskets. My upper intake is the Plastic One.
I went to Advance auto and bought Part# MS90732 (Fel-Pro).
When I removed the upper intake, I found an Fel-Pro Gasket (part# 96684)on between the upper and lower intake. Keep in mind that the old rubber gaskets were still on Upper Intake grooves.
Im confused. Why did the gasket kit only come with what's on Pic# 2 (including the O-ring)
What is this Fel-pro (96684) for?
I'm not sure where the thick gasket goes. Do i need to buy the Fel-Pro 96684 gasket?
Pic#1 shows what i removed from the upper intake.
Pic# 2 are the new parts that came in the MS90732 Kit including the EGR tube O-Ring
This is the gasket kit ( sorry about the quality of pic)
Hi,
