Mirge
- November 27, 2009
- Tulsa, OK
- '98 Eddie Bauer
I've replaced the blend door... easy enough. Worked great -- for a while. Naturally, the actuator took a crap a month or 2 after.
I just installed a Dorman brand actuator P/N 604-201..... didn't work. Little motor won't spin. Put back old actuator... motor spins. So, I figured I'd take a look inside of them.... old actuator had a gear with 3 missing teeth. Bingo.
After some playing around and getting frustrated, I figured I'd try swapping the gears....... no dice.
SO..... where can I get a blend door actuator that will actually WORK? Got this one from O'Reilly Auto..... checked RockAuto.com, but all I see is the exact same part I have already tried.
Pretty urgent... thanks.. if I can buy one that works from someone on the boards, I'd much rather do that. Thanks!
EDIT: old actuator says:
F87H-19E616-AA
R242 a06282
ATC
F87H-19E616-AA
R242 a06282
ATC
