Urgent help needed. 1991 Explorer transfer case shift motor rebuild.
Desert exploring
1991 Explorer Eddie Bauer
The 4x4 was not working in my recently purchased 91 Explorer so, using threads on this forum I diagnosed the issue to be the plastic bushing in the transfer case shift sensor. I took the motor off the case and removed to sensor cover, now I am stuck. I cannot figure out how to push the first “layer” out of the sensor to get to the bushing. Whoever has done this repair before.. what did you do? Sorry for dark pic.. I’m working under the truck.
  • Like
Reactions: imp
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
imp
Location
West-Central AZ along the Colorado River
59 Ranchero F250 D'Line
@Desert exploring
Obviously, those strips seen are ridden upon by contacts, probably spring-loaded. Can you wiggle the internals from side to side, confirming bushing wear-out? If the inside piece moves to where the contact is off the strip, no moto. Beyond that, never had one apart, so I guess I'd replace the unit. It's likely that bushing may not even be available.
Desert exploring
@imp
Thanks for the reply, I gave up and shoved it back on the transfer case, the force of the “key” managed to push the gear piece out far enough, and to my surprise it pulled right out! The bushing inside was shredded to pieces, confirming the cause to the 4x4 issue and it will be replaced when I get to a hardware store.
Not sure if anyone else had this happen, but it was a frustrating thing to occur when everyone else is talking about how easy it was to remove it. Lol! Maybe I was doing something wrong..
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
imp
Location
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
@RangerX
News to me that rebuild parts are available. Have tried buying some starter motor parts recently, they sell only the whole dang thing! imp
Not sure what exactly you saw in the thread to make the comment, but keep in mind,
1. The thread is 15 years old.
2. I didn’t write the thread.
3. I only linked the thread for general rebuilding info as it’s the best thread on the subject that this board has.
4. The OP wasn’t asking about where to buy replacement parts.
S Urgent help needed.... Stock 1991 - 1994 Explorers 2
I Urgent Help Needed -Airbox vacuum line- Stock 1991 - 1994 Explorers 8
J Urgent help needed Stock 1991 - 1994 Explorers 10
F Urgent help needed. 92 xlt Stock 1991 - 1994 Explorers 5
F urgent help needed. steering problems Stock 1991 - 1994 Explorers 4
R need urgent help fast!!! CAM POS SENSOR Stock 1991 - 1994 Explorers 4
R need urgent help with my exhaust Stock 1991 - 1994 Explorers 1
I Electrical problem, urgent help please Stock 1991 - 1994 Explorers 2
S urgent help Stock 1991 - 1994 Explorers 3
E urgent 91 4x4 problem Stock 1991 - 1994 Explorers 5
R URGENT!! Charging problem! Stock 1991 - 1994 Explorers 5
M Fuel Pump and Gas Gauge Questions - URGENT Stock 1991 - 1994 Explorers 13
J Brake Pad Install. Urgent! Stock 1991 - 1994 Explorers 5
M Urgent! Stock 1991 - 1994 Explorers 96
C Need help with a 1994 Explorer parking brake parts Stock 1991 - 1994 Explorers 4
9 Need help Stock 1991 - 1994 Explorers 1
C Need help on rear main brand Stock 1991 - 1994 Explorers 7
D Help explorer 94 Stock 1991 - 1994 Explorers 2
C help me with decoding self-diagnosis Stock 1991 - 1994 Explorers 9
J Bad misfire please help Stock 1991 - 1994 Explorers 2
S Rim Sizing Help! Stock 1991 - 1994 Explorers 5
K Help...Drilled out ignition won't turn Stock 1991 - 1994 Explorers 11
A Under hood wire harness. HELP (please) Stock 1991 - 1994 Explorers 12
massacre Need Help Fuel Pump Circuit Stock 1991 - 1994 Explorers 30
9 1994 Mazda B4000 4x4 Problems Please help. Stock 1991 - 1994 Explorers 4
A Aftermarket Security System help? Stock 1991 - 1994 Explorers 3
J Help! No start, fuel pump constantly running Stock 1991 - 1994 Explorers 3
S Help PLEASE Stock 1991 - 1994 Explorers 3
K NEED HELP! Stock 1991 - 1994 Explorers 4
Z Door strike help! Stock 1991 - 1994 Explorers 2
T Need Quick Help... SOLVED.. Thank You Stock 1991 - 1994 Explorers 36
E Need help identifying wires behind radio Stock 1991 - 1994 Explorers 7
A Need help identifying a cluster of 4 wires Stock 1991 - 1994 Explorers 27
Hossexplorer A/C not working? help! Stock 1991 - 1994 Explorers 9
9 HELP! Any New Mazda or Aftermarket OEM Headlights out there at all?? Stock 1991 - 1994 Explorers 8
A Help wiper transmission Stock 1991 - 1994 Explorers 2
S Help: removing rear door windows and regulator. Stock 1991 - 1994 Explorers 1
G My 1994 explorer...the right brake light and blinker wont work with a new bulb. PLEASE HELP!!! Stock 1991 - 1994 Explorers 2
A Help on what to buy to replace stock stereo Stock 1991 - 1994 Explorers 9
D NO HEADLIGHTS 1994 FORD EXPLORER - HELP PLEASE Stock 1991 - 1994 Explorers 3
T Need help wiring demotor electric fan kit Stock 1991 - 1994 Explorers 0
N Please help With auto trans Stock 1991 - 1994 Explorers 5
C Help - 1994 Explorer 4x4 Switch Gear ID and Troubleshooting Stock 1991 - 1994 Explorers 0
L Need Keyless Entry 1993 Ford Explorer XLT Help... Stock 1991 - 1994 Explorers 5
C Need expert-level PCM/Electrical help with ECT and O2#1 CEL's (#116 KOER only and #176 KOEO only) Stock 1991 - 1994 Explorers 5
R 1993 Ford Explorer Sport 4.0 L V6 Automatic Transmission (First car and I need help) Stock 1991 - 1994 Explorers 21
A HELP! Fuel issue.. Stock 1991 - 1994 Explorers 12
U Help! Coolant leak! Stock 1991 - 1994 Explorers 11
L Need Help Installing Aftermarket Radio in 1993 Explorer with JBL System Stock 1991 - 1994 Explorers 2
S Rough Idle when engine is hot HELP!!! 1993 explorer Stock 1991 - 1994 Explorers 10
Similar threads
