cjben
- December 28, 2010
- Illinois
- 2004 ford explorer
Need the vehicle running before Monday if possible. It's a 2004 4wd 4.6 v8 with 140,000 miles. My wife was driving around town today and had to park it at her daughter's house because even if you floor it,the engine will only rev to about 1500-1800 rpm's and idles really low,maybe 600 rpm. she said right before it started running bad,there was a bad smell. Also there is a humming/rattling noise that sounds like it's coming from the upper intake/throttle body area. I went and looked at it,tried to pull codes. The check engine light isn't on and there are no codes stored in the computer. A couple of days ago,there was code po420 (Catalyst System Efficiency Below Threshold (Bank 1)and the check engine light was on. Engine was running fine. I cleared the code,and it never came back. I am not sure this is related,just trying to give all info possible. Thanks for any help!!
