USB Hub upgrade?
VandyCWG
Location
Spring Hill, TN
Spring Hill, TN
2017 Explorer Limited
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
MM07
MA
2018 Explorer Limited
Not sure if that would work. I'd call a dealer and try to find an OEM part and number.
Joe Stewart
Austin, Texas
2015 Explorer XLT
That unit will work, but they do have a small frame one and a large frame one. Also, with 3.4 version of Sync, it is supposed to support Quick Charge.
I am looking at doing this also, but the only large one i can find is 120.00. I am looking to spend a little less.
Joe Stewart
Austin, Texas
2015 Explorer XLT
Zodiac
2017 Ford Explorer Sport
It shows on the chart that this is compatible with my '17 Explorer.
Have you gotten a chance to test to see if usb-pd charging works?
I have been interested in adding this but wasn't sure if android auto would be supported via the usb-c port.
Thanks.
Joe Stewart
Austin, Texas
2015 Explorer XLT
i have it ordered. From what i have read, you must have 3.4 installed to take advantage of Quick Charge.
I will post when i have it hooked up.
Zodiac
Thanks, I'm assuming you purchased the one in your link as opposed to the first post since it had compatibility with the Explorer?
I look forward to seeing how it goes!
Joe Stewart
Austin, Texas
2015 Explorer XLT
The one i ordered is more expensive, but i wanted the larger one. Also this one on EBAY is 149.00.
