Rolkin
- March 4, 2006
- Springfield, Mo
- '92 XLT
Just bought a '92 xlt for a work vehicle. Took it to get inspected so I can get it titled and Licensed but it failed.
I don't know squat about cars but my dad does, so bear in mind I don't have to much of a clue, but I'd like to try and fix this stuff myself seeing how I don't have much money to put into it right now.
(Question 1)
Ok when I bought the truck I knew something was up with the brakes, the guy said the rear breaks or break control needs to be adjusted, but when I took it to get inspected they said it was the master cylinder. At low speeds the petal sinks to the floor to stop and and higher (over 40) it kinda vibrates like I have uneven rotors or something. Also when I had to slam on the brakes it jerked to the left.
Is all of that related to the master cylinder? I checked the fluid lvl and it's full.
(Question 2)
The push button 4x4 doesn't work, from what I read on the trans page here, a click followed by another 3 secs later can probably be fixed by realigning the control motor, but I tried it again yesterday and it didn't even click. Is there something beside the motor that can go wrong?
(Question 3)
When I bought it the guy showed me that there was a vacuum hose that he never reconnected because he couldn't find where it went. I'm wondering from another article I read if this could have anything to do with the transmission fliud *disappering* , is it going in the oil as the article suggested ? I'll try and take a picture of it to help out. I figured it was for the cruise control because that doesn't work.
Also kinda the same question but I have to put some transmission fluid in every week or so according to the previous owner, what could be the cause of this if not whats listed above? It doesn't leak on the ground just kinda disappers.
(Question 4)
There's a high pitched whine coming from the truck I think it might be coming from the fuel pump. What might it be? My dad can't hear it at all due to working in a body shop most his life, so it's decently high pitched, it kinda sounds like maybe a vacuum hose isn't on all the way or air getting sucked into something. The previous owner replaced it with a used fuel pump and soon after the gas gauge stopped working. I'm kinda wondering if the fuel pump isn't sealed right or something. I assume it's in the tank? It also died one while idling after it had been warmed up pretty good, I though that might also be realated or maybe it's just the filter?
Thanks for any help, my dad's gone for a couple weeks and I need to get this titled within 20 days or the fines start adding up so I'm trying to figure out what parts I might need and what they cost so when he does get back we can hopefully get this knocked out or at least give him some other idea's he might not think of.
Oh yea and the picture of the vacuum hoses...
Here
(Question 1)
(Question 2)
(Question 3)
(Question 4)
Here
