bojans
- April 24, 2006
- McHenry, Il
- 2006 Explorer Limited
Took my 06 V8 with 95k into my local shop to have them locate an exhaust leak that has been going on for a few month. The leak is not that bad and only occurs when the car is cold. Shop located the leak and the culprit appears to be a passenger side manifold gasket. They did not want to touch the replacement of this part because they are concerned if one of the studs snaps off the only way to repair that is to pull the head and then you are into big money. They suggested seeing if any of my local Ford dealers had a method for dealing with a broken stud in the engine compartment.
Is this a real concern or are they just being overly cautious?
