Hello Everyone
I have a 1996 Explorer Premium Sport (2 door). For the past few weeks I have noticed an antifreeze smell. A mechanic told me that both heads were leaking Left side more so that the right. She has about 80,000 miles and everything is orginal. I was told that to repair the leaking gaskets could be expensive and if the the heads are damaged I might need a new engine? I thought a new engine lets make it a V8 then...
I've search this forum and few other places, and found information more for the gen1 explorers and ranges. I wondering how that compares to an engine swap for a gen2 (96 Explorer).
I'm looking for a general swap- (not a race truck= high Hp, or for off road use etc), not a drastic conversion.
What will I need? (this is what I've read-please correct me if its wrong or if there are better ideas).
1. V8 engine= 302 from an explorer works the best 96 to (?); is one year better than another?
2 Transmission= can I use the transmission already in the 96 explorer or do I need to use a different one. A trans that is used in the V8 explorers?
3. Wiring = It has to be a harness for the v8, anything else?
4. Swap kit (motor mount, different oil pan etc). The forum mentioned L&L Products, Advance Adaptors, etc. The web sites look more for off road use and has items for Bronco (not specifically exploreres)? Will I need the entire kit?
5. Is there anything else that needs to be converted?
It seems that the V8 swap would be easier for the 96 explorer than for the eariler explorers and Bronco II. I could be wrong?
Two things worry me. The v8 was not an option for the 2 door sport explorers, and I have a switch to change for 2 wheel drive to 4 wheel drive, and the V8 were AWD (I think). Is this an issue with the conversion?
Any information for the V8 swap for a 96 2 door explorer will be greatly appriciated. A referral to previous post, anyone have a guide or even knows a mechanic in Northeastern Pennsylvania that can perform this swap.
Any help will be greatly appreciated. Thanks for the help.
