BrianV
- November 28, 2005
- Austin, TX
- 98 Mounty 5.0L
Car Info:
98 Mountaineer V8 2WD w/ 114k miles
The slam isn't really bad and it rarely happens, typically only under medium throttle.
All gears shift perfect, but 3rd to 4th sometimes slightly bangs into gear. You can hear/feel what can best be described as a dropping feeling/slamming sound.
It hasn't gotten any worse or any better over time. I'm curious if this is a common problem.
Also sometimes when in fourth gear just cruising and I give it medium throttle, it shakes and stutters before it makes the downshift to third. However, if I use the OD off button it downshifts perfectly, also if I give it a lot of throttle it downshifts perfectly (making me feel that it's really not a big problem).
It's such a minor problem but I'd just like to know what it is.
Car History: I bought it about 3k miles ago. It has 114k miles now and based on the records I've seen it's never been tranny flushed. There is records of the fluid being topped off on occassion. I put LubeGuard Red in a few months abck and it seemed to help. The oil in the tranny is fairly dirty, but I fear doing a flush now may cause more problems. What's a rebuild cost anyway? Based on how the tranny is acting, I feel there's still another good 40-50k miles in it, especially since it's only one issue between 3rd and 4th under a very particular throttle level. I've heard of a lot of people complaining about minor tranny problems and not worrying about it and going another 75k miles, alternatively I've read of people changing their fluid and then only getting 5-10k miles left.
I also wonder if the problem is TC related? Any advice is appreciated.
