Vaccum leak test results | Ford Explorer Forums - Serious Explorations
SoCalJ
Torrance, Ca
1997 Ford Explorer
1997 Ford Explorer V6 4x4 (awd) ohv 138,000 miles. I had my engine diagnosed and the tech said the results were a faulty carbon canistor and vent solenoid. They then performed a smoke test and located a " vaccum leak at carbon canistor and vent solenoid" P0446
What does the vent solenoid (carbon canistor vent solenoid) look like? Where should I start? Should I replace the entire carbon canistor? Will the check engine light automatically shut off when the problem is fixed, or do i have to get the engine rescanned?
Any help would be greatly appreciated. I just don't know where to start or what to do.
Thanks
if anyone can help me out with this issue, please let me know. I have to pass smog and I refuse to pay someone for a job that I am able to do.
Thanks
....or it is called a Solenoid purge valve..:dunno:...I will get you a link to info, brb...;)
I found your other thread here where dogfriend already gave you some great info..:scratch:
http://www.explorerforum.com/forums/showthread.php?t=228627&highlight=purge+valve
...Which should have led you to this thread...
http://www.explorerforum.com/forums/showthread.php?s=&threadid=71263&highlight=evap
...Heres a couple more threads with info...;)
http://www.explorerforum.com/forums/showthread.php?t=131933&highlight=vent+solenoid
http://www.explorerforum.com/forums/showthread.php?t=93175&highlight=vent+solenoid
Thanks Tbars4 for the great links. I'll go through them.
Dogfriend did give me great info and I appreciate it, I just don't know where to start or what to replace. It seems like there are 2 areas that I am not sure about. One is the purge valve under the battery tray and the other is the canister/solenoid above the spare tire. I'm guessing that I'll have to replace both parts just to play it safe.
The computer diagnosis stated "vent solenoid" which is where I am getting confused.
...The last 2 threads should answer that for you but all of the ones I posted have great info..:biggthump
