CaribouMainiac
- November 10, 2014
- 1996 Explorer Sport 4WD
My first post....
I picked up a 96 Explorer Sport model about a week ago, and have been picking up all kinds of good info from this forum.
I purchased the truck to haul a small Boston Whaler.... so I've been going through the vehicle, looking for little things. ( so far, I've replaced the instrument cluster lamps and other interior lamps w/ LEDs', .... and while I had the dash apart, I ran the wires for the "Brown Wire Mod", but haven't picked up a switch yet. I've purchased a backup GEM on Ebay, which should arrive next week. ( as you can see below, I may have an issue w/ the GEM I have.... but haven't quite figured out the 4WD engagement issue. ( the Transfer Case was recently "gone thru", and looks pretty clean, but, as you can read below.... I don't think the guy who did the work, did a thorough job. )
I noticed that the truck does not like to go into 4WD, but will, eventually.
Once I get it to go into 4WD- Auto.... I just leave it there. (not my daily driver)
There are some apparent electrical gremlins.
I had a parasitic draw on the battery, .... I was able to track that down. (it was an old, aftermarket security alarm.... it didn't work anyway... so I removed it )
This evening I crawled under the truck and took a look at the connections to the transfer case.... it was pretty ugly.... frayed wires, shorting out against each other....both at a speed sensor, and, one other plug had bare wires ..... and THEN...... I noticed a place for a vacuum hose.... but, no hose in sight.
So,.... I can fix the frayed / shorted wired,.... but,....even after searching the forum, I can't seem to find an answer to where the other end of this missing hose goes. I read about a "box" on the passenger side of the front axle,... and I do see some small vacuum hoses coming out of that "box" area.... but no "open ports"..... and the smaller vacuum hoses that do come out of the "axle box" head towards the passenger headlight area. (not towards the transfer case)....
So.... finally.... here is the question: Where, exactly does that missing vacuum hose attach at the other end ? ( it is obvious where it attaches to the Transfer Case ). Transfer case # is: Borg Warner F57A-7A195-CA. (which I believe is also called a "4405")
So..... anybody out there ?
btw... that Brown Wire Mod will come in handy for me.... the boat ramps can be very slippery around here.... and being able to slowly crawl up a slippery ramps, with all four wheels ... without the rear wheels "slipping first", is a desired effect.
