Solved - Vague highway steering | Ford Explorer - Ford Ranger Forums - Serious Explorations
Solved Vague highway steering
Dan R
Santa Clara, CA
1993 Ranger 3L RWD
Maybe it's just for the suburbs.
On the highway at 60+,straight ahead, the steering feels like it is disconnected. Lots of play.
The steering has a reconditioned gear box and new links. Only a very marginal improvement. I will be changing the pump because it is so noisy.
What else can be done?
Oxthe3rd
Hamburg NY
1992 Ford Explorer XLT
Have you checked the rag joints on the steering shaft?
Oxthe3rd
Hamburg NY
Power steering just adds assistance to the steering. I would have someone turn the wheel while you look at shaft, steering box and tie rods. Something has to be loose to feel disconnected.
How is it at low speed?
Dan R
Santa Clara, CA
1993 Ranger 3L RWD
Low speed OK I suppose not exactly a go cart. There seems to be a fair bit of play around straight ahead position. The steering wheel has to move 2-3 in in either direction before movement is felt.
Would an alignment help?
Oxthe3rd
Hamburg NY
Alignment would pull.
That's exactly how much play I had when my tie rods were bad. Felt like I was driving in a movie. Moving the wheel with no response.
Dan R
Santa Clara, CA
1993 Ranger 3L RWD
What about that adjustment rod on top of the steering box? Would tightening that a quarter turn help? Not sure what you mean by "pull" re. alignment.
Oxthe3rd
Hamburg NY
It could help but only if it's a loose box and as you said it has a reman steering box.
By pull I'm talking about if you don't hold the wheel does it pull one way or the other.
Dan R
Santa Clara, CA
1993 Ranger 3L RWD
No it does not pull and tire wear is even.
I will put it up on jacks and check for loose fittings
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
I had loose steering with a good amount of free play before actual steering engagement before, couple inches either way. The splines where the steering intermediate shaft connects to the steering gear box had worn down enough to cause it. This was due to hard off-roading on my part I'm sure, but your reman box could have come that way, could even be my old box! Those splines may not get looked at when they rebuild 'em.
Dan R
Santa Clara, CA
1993 Ranger 3L RWD
I fixed it today. The half inch nuts on the rag joint were not tight enough. I did replace it last year. Now they are tight.
Oxthe3rd
Hamburg NY
Glad it worked out.
Dan R
Santa Clara, CA
1993 Ranger 3L RWD
Thank you. I would not call it a transformation but the truck is now so much more steady on the highway. Just a small tightening.
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
Thanks for posting your fix. Some simple things get overlooked and things will loosen up over time if they've been replaced without loctite or torqued down good.
