BrandedSohcman
- August 6, 2016
- FLORIDA
- 1998 Ford Explorer
I had transmission slippage in all gears. Replaced the blown out valve body gasket not the spacer plate. I didn't do any repairs to servo. I replaced servo gasket, pan gasket. Everything worked great for about 5 miles then after a brief engine off and start then reverse. I drove about 25 feet and it started slipping second gear then after a few miles it started slipping first gear. Works great over 35 MPH. It was working great with perfect response immediately after replacing the gaskets. I did notice some slight scoring near the top of the servo rod. What about the o rings? Could you tell me if something was wrong with the reverse servo would that cause another gasket blow out?
