mcfixstuff
- February 23, 2021
- Location
- Katy, TX
- Katy, Texas
- 1994 Explorer XLT 4WD A/T
I have been having issues with my 1994 Explorer the last couple months. The transmission started giving me issues while cruising at 32-45mph. It doesn't want to sit in 4th gear. It either dumps into overdrive from 3rd, or if I put the transmission into OD lockout, the RPM needle will just bounce around, and will give me a very annoying ride while cruising at those speeds. I know the transmission should not be going into overdrive at 950rpm at 35 miles an hour.
I took out the valve body to replace a few parts like the solenoids, and gaskets. When I opened up the valve body, it was immaculate. No gunk, completely clean. The 3-4 solenoid was not the right size, so I just cleaned off the old one with brake cleaner and put everything back together.
The car shifts fine when cold, but once it warms up, it loses its grip on reality between 32-45mph. I am wondering if this is electrical since overdrive is controlled electronically, or if it's still an issue with the valve body.
Anything I can do to test the electrical side of things?
No slippage in any gears during hard acceleration. When entering the freeway, it shifts through all the gears fine, just when I'm cruising I have troubles. I have checked the fluid levels so many times. They are all good. I do have an issue where there's a hard shift from 1-2, and it clunks into reverse and drive, but that has been there forever.
Where do I start. I do not want to try to rebuild the valve body myself. I'll just buy a rebuilt one and slap it in if its either the solenoids or the valve body.
Thanks!
Thanks!
