JCbucks
- July 20, 2014
- Columbus, OH
- 2007 Ford Explorer XLT
I have an interesting issue with my V6, 2WD 2007 Explorer with about 128,000 miles on it. Two weekends ago I had driven around 110 miles at 70 mph when the vehicle lurched. Around 2 seconds later the engine stopped. The radio stayed on and multiple warning lights came on; among them, the one for the charging system. I glided to the edge of the road, put the vehicle in park and immediately tried to start the engine. It did not start (it was totally dead, no lights, it won’t crank, no “click”, nothing.) I waited a few (maybe 5?) minutes and tried to start the vehicle and it started. It then ran for around 10 miles and shut down again. Replaced alternator and made it around 10 miles down the road before stopping again. I waited for a few minutes and was able to start the vehicle again. I drove at 60 mph with the AC off and was able to make it the remaining 80 miles or so home without it stopping.
I have since replaced the battery (it was old), the fuel pump relay and the PCM module relay, but the problem still exists once I drive around 70 mph. It has quit after going 3 miles; however, I’ve also made it as far as 25 miles prior to it stopping. Ambient temperature doesn’t seem to affect as it has stopped running with ambient temperatures of 63F and 90F. It has not stopped when I have been driving under 55 mph with the exception of one time that I restarted the vehicle around 3 minutes after it had shut down and tried to pull back on to the interstate and two times described at the bottom. The vehicle only made it up to 45 mph before stopping again. The cruise control has been set during some of the instances where the engine has stopped, but was off during others. When the car stops all of the warning lights on the dash illuminates, the radio stays on and AC continues to run. When trying to restart the vehicle immediately it quits, the anti-theft light does not turn on (none of the dashboard lights do either, it is just dead), but after a couple of minutes I am able to start the vehicle and the anti-theft light turns on and stayed solid for 3 seconds or so.
The codes that I have found are below:
Code Description Causes
U1900 controller area network (CAN) communication bus malfunction Bad PCM is one of many possible causes
P2105 throttle actuator control system - forced engine shutdown
P0446 EVAP - vent control system malfunction Bad vent valve, bad PCM, wiring short
P0455 EVAP - leak detected Bad gas cap or leak in EVAP line
P0600 serial communication link
P1000 onboard diagnostic to drive cycle Did not complete full diagnostic check
U0500 vehicle speed sensor (VSS) not working properly Bad VSS, bad (or incorrectly configured) PCM, loose wire
The oil change required light is on, but I recently had the oil changed and I suspect that the alarm was not reset. The oil level is good.
Most recently, it appeared to operate fine (ran 20+ miles at 65-70 mph) immediately after I replaced the PCM module relay; however, I pulled over and filled the gas tank, got back on the highway and it stopped after 2 miles or so. I started it a couple different times and it only ran for 30 seconds or so before shutting down again. I waited for around 15 minutes, started it and made it 30 miles or so at 60 mph with no issue.
Also, there have been two separate incidents where we were driving 70 mph for 10 miles or so, took an exit and made an immediate hard right at the end of the exit ramp. It stopped running immediately after making the right hand turn.
